Best Watches for Hiking: Find the Right One for Your Adventures
SuuntoClimb — 16 studenoga 2026
From everyday walks and short hikes to multi-day adventures and long-distance backpacking, the right outdoor watch makes your time on the trail easier to manage.
Different kinds of hiking call for different features. An altimeter, barometer and compass give you useful outdoor information, helping you track elevation, watch for changes in air pressure and find your direction. On unfamiliar routes or challenging terrain, GPS positioning, offline maps and route navigation add another layer of support.
This guide looks at some of the best hiking watches from Suunto, their key features and where each one shines, to help you choose the best hiking watch for your adventures.
What to Look for in a Hiking Watch
How do you know which hiking watch fits you best? Along with your everyday preferences, consider what features you'll likely need and how they perform outdoors.
Key Outdoor Information
On a hike, elevation, air pressure and direction help you understand your surroundings and make route decisions. Each sensor plays a different role on the trail:
  • Altimeter: Shows your current elevation and tracks cumulative elevation gain, so you can follow changes in altitude throughout your hike. On a climb, for example, you can check your current elevation and total ascent to see how much climbing you've done.
  • Barometer: Shows air pressure and its trends, a useful signal for changing weather. While resting at camp or taking a break on the trail, you can watch the pressure trend as an extra reference for the conditions ahead.
  • Compass: Shows your general direction and supports traditional navigation with a paper map. At a trail junction or in featureless terrain, you can compare the map with the landscape around you to identify each path. When heading for a pass or campsite marked on the map, you can follow its bearing to hold your direction.
A hiking watch with full ABC (altimeter, barometer and compass) functions keeps you informed about your surroundings as outdoor conditions change.
Battery Life
If you often take long hikes or multi-day backpacking trips, battery life and power options are key factors. Outdoor watches differ widely in battery design and runtime.
Some traditional ABC watches use user-replaceable batteries that last for months or longer in everyday use. If you'll have few chances to charge along your route, a spare battery keeps you going. Before you set out, check the battery level and pack a spare to suit your trip length and expected use.
GPS watches usually have built-in rechargeable batteries, and their runtime depends on GPS mode, screen use and other active features. High-accuracy GPS modes use more power, so look beyond the advertised battery life and understand how each setting affects runtime. Weigh your trip length, positioning needs and access to charging when choosing a GPS mode and planning when to charge.
Navigation Needs
When choosing a hiking watch, think about how you like to navigate. If you want to check your location on your wrist, view digital maps, follow preloaded routes and record your tracks, look for a GPS hiking watch with positioning and route navigation.
If you prefer planning with a paper map, reading terrain features to fix your location and checking direction with a compass, an ABC outdoor watch may suit you better. These watches use an altimeter, barometer and compass to provide outdoor information and support traditional navigation.
You can also have both. Many GPS watches for hiking include an altimeter, barometer and compass, combining digital navigation with essential outdoor information.
Durability and Readability
On the trail, your watch faces rain, dust, cold and the occasional knock. When comparing hiking watches, look at water resistance, crystal material and overall construction with your usual routes in mind. If you often hike in the rain, prioritize water resistance. If your routes cross rocky ground where bumps and scrapes are likely, consider the scratch resistance of the crystal and how well the case protects the watch.
Screen readability matters just as much. On open trails in direct sun, you need to read the time and navigation at a glance, and in the woods or after sunset, you still need to check elevation, direction and other data in low light. Look beyond brightness to contrast, font size and backlight options to judge how easily you can read the information you use most.
Best Suunto Watches for Hiking
With these needs in mind, we've picked two Suunto hiking watches: Vertical 2 and Core 2. Each supports a different navigation style and kind of hiking.
Quick Picks
Choose Suunto Vertical 2 if you want:
  • GPS Navigation and Offline Maps: Dual-band GNSS, offline maps, route navigation and Climb Guidance.
  • Extended GPS Battery Life: Up to 65 hours in the highest-accuracy GPS mode and up to 250 hours in Tour mode.
  • Built-In LED Flashlight and Outdoor Features: A built-in LED flashlight plus altimeter, barometer and compass.
  • Hiking and Multisport Tracking: Tracks distance, pace, heart rate and cumulative elevation gain, with multiple sport modes.
Choose Suunto Core 2 if you want:
  • Classic ABC Functions: Altimeter, barometer, digital compass and Storm Alarm.
  • Traditional Outdoor Navigation: Bearing Tracking and magnetic declination settings for navigating with a paper map.
  • Long-Lasting User-Replaceable Battery: A CR3032 coin cell with up to 15 months of battery life in Time mode.
  • Durable Outdoor Design: 10 ATM water resistance, Gorilla Glass and MIL-STD-810H testing.
Below, we look at each watch in more detail, including its key benefits, its trade-offs and the hiking scenarios it suits best.
Suunto Vertical 2: A High-Performance GPS Watch for Hiking
Suunto Vertical 2 is a GPS sports watch designed for outdoor activities. As a hiking watch with GPS, it combines high-accuracy GPS positioning, offline maps, route navigation, and multiple sport tracking features to help you navigate trails, record your hikes, and monitor your performance.
In unfamiliar areas, tree cover, trail junctions and complex terrain can make it hard to stay on course. Before you set out, plan your route in the Suunto app, download offline maps and sync them to your watch. On the trail, you can see downloaded maps, your current location and your planned route right on your wrist, even without mobile coverage, so you rely less on your phone. Dual-band GNSS delivers more accurate positioning in complex terrain. If you stray from your route, deviation alerts and turn-by-turn directions let you know you've gone off course. On routes with repeated climbs and descents, Climb Guidance shows the uphill and downhill sections ahead, helping you anticipate the terrain and manage your energy.
For long hikes and multi-day trips, GPS battery life is a key part of choosing a backpacking watch. Vertical 2 offers multiple GPS battery modes, so you can match the mode to your trip length and positioning needs. In Performance mode with All-Systems GNSS + Multi-Band, GPS tracking lasts up to 65 hours.
For longer trips, Tour mode extends battery life to up to 250 hours, with reduced positioning accuracy and heart rate measurement switched off. Before you set out, choose the mode that best fits your expected trip length and GPS needs.
On the trail, Vertical 2 tracks distance, cumulative elevation gain, pace and heart rate, so you can follow your progress and effort. Afterward, review your route and activity in the Suunto app, explore the data from your whole outing and use those insights to plan your next hike.
In the mountains, weather and changing light matter too. Vertical 2's altimeter, barometer and digital compass make it easy to check your elevation, follow pressure trends and find your direction, and Storm Alarm alerts you when air pressure drops fast enough to meet your alarm settings.
The built-in LED flashlight offers white and red light for early starts, late arrivals at camp and sorting gear after dark.
For a closer look at using these features in winter conditions, see our guide to planning a winter mountain adventure.
Who Is Suunto Vertical 2 For?
Vertical 2 is made for hikers, mountaineers and outdoor enthusiasts who want to see their location, navigate with offline maps and routes, and record every step of the journey. Its long GPS battery life and multiple battery modes cover everything from day hikes to multi-day trips, and its refined design and broad sport features make it just as suited to everyday wear as to big adventures.
Suunto Core 2: A Reliable ABC Watch for Outdoor Adventures
Suunto Core 2 is a classic ABC hiking watch with a durable build and 10 ATM water resistance, ready for hiking, camping and other outdoor activities.
In the mountains, the altimeter tracks your elevation changes and the barometer follows pressure trends. If pressure drops by at least 4 hPa within 3 hours, Storm Alarm alerts you to a possible approaching storm. Storm Alarm runs in Barometer Profile; when you're climbing or descending steadily, switch to Altimeter Profile to follow elevation changes. Weather also affects barometric altitude readings, so calibrate the altimeter at a point of known elevation.
If you navigate with a paper map, Core 2's digital compass is a great partner. Bearing Tracking shows your target bearing so you can hold your intended direction, and the magnetic declination setting corrects for the difference between magnetic north and true north, making compass readings easier to use alongside a map. Core 2 is a pure ABC watch, with no GPS positioning, digital maps or GPS track recording, so you'll fix your location with a topographic map, the terrain around you and your own navigation skills.
On longer adventures, Core 2's user-replaceable battery is a real advantage. Its CR3032 coin cell lasts up to 15 months in Time mode, depending on use. You can swap the battery yourself with no charger needed, and the low-battery alert gives you time to prepare a replacement.
Readability and simple controls matter on early starts, cloudy days in the woods and evenings at camp. Core 2's high-contrast LED dot-matrix display has switchable red and green backlights for easy reading in any light. The red backlight helps preserve your night vision, and physical buttons let you switch functions with gloves on.
Who Is Suunto Core 2 For?
Core 2 is made for outdoor enthusiasts who love adventure and exploration, whether you hike, camp or head into the wilderness all year round. If you value durability and want quick access to elevation, air pressure and direction, plus a compass for map navigation, Core 2 covers the essentials.
It's also ideal if you prefer a simple, practical watch with long battery life and navigate without GPS.
Suunto Vertical 2 vs. Suunto Core 2
The table below compares the key features and specifications of the two watches, helping you quickly understand their differences.
Comparison Suunto Vertical 2 Suunto Core 2
Watch Type GPS Outdoor Watch ABC Outdoor Watch
Positioning and Navigation Dual-band GNSS, offline maps No GPS positioning or digital maps
Route Guidance Route deviation alerts, turn-by-turn directions, waypoint guidance, and Climb Guidance Digital compass, Bearing Tracking, and magnetic declination settings for traditional map navigation
Battery Design Rechargeable lithium-ion battery Replaceable CR3032 coin cell battery
Battery Life Up to 65 hours in Performance mode; up to 250 hours in Tour mode Up to 15 months in Time mode
ABC Functions Altimeter, barometer, and digital compass Altimeter, barometer, and digital compass
Storm Alarm Supported Supported, but only active in the Barometer Profile
Built-in LED Flashlight White and red light Not supported
Display 1.5-inch LTPO AMOLED display, up to 2,000 nits brightness 1.3-inch LED dot-matrix display with red and green backlights
Crystal and Water Resistance Sapphire crystal glass; 100 m water resistance Corning Gorilla Glass; 10 ATM water resistance
Best For Hikers who need GPS navigation, offline maps, and activity tracking Hikers who prefer traditional navigation, long battery life, and essential outdoor information
Conclusion
An outdoor watch is more than a timepiece. It's a trusted companion for hiking and exploration. Whether you're on a familiar mountain trail or somewhere completely new, Suunto watches give you the information you need to track your journey, understand your surroundings and take on every challenge with confidence.
FAQ
Is an ABC Watch Enough for Hiking?
An ABC watch gives you elevation, air pressure and direction, and supports traditional navigation with a paper map. It doesn't offer GPS positioning, digital maps or track recording, so whether it's enough depends on how you like to navigate, the trails you hike and your map-reading skills.
Does Suunto Core 2 Have GPS?
No. Suunto Core 2 is an ABC watch. Its built-in altimeter, barometer and digital compass provide outdoor information and support traditional navigation, without GPS positioning, digital maps or GPS track recording.
How Do You Calibrate the Altimeter on a Hiking Watch?
Find a spot with a known elevation, such as a trail sign or summit marker. Then enter that elevation in your watch's altimeter settings, or use its calibration function to adjust the reading.
