FREE SHIPPING FROM €150 | SIGN UP FOR NEWSLETTER | NEW LOWER PRICES
Suunto Ambit2 R User Guide - 2.0
Using 3D compass
Suunto Ambit2 R has a 3D compass that allows you to orient yourself in relation to magnetic north. The tilt-compensated compass gives you accurate readings even if the compass is not horizontally level.
The compass is a temporary display that needs to be activated.
To activate the compass:
  1. While in a sport mode, keep Next pressed to enter the options menu.
  2. Scroll to Activate with Light Lock and select with Next.
  3. Scroll to Compass with Start Stop and select with Next.
compass mode includes the following information:
  • middle row: compass heading in degrees
  • bottom row: toggle between the current heading in cardinal (N, S, W, E) and half-cardinal (NE, NW, SE, SW) points, time and empty view with View
compass mode
The compass will switch itself to power saving mode after one minute. Reactivate it with Start Stop.
For information on using compass during exercise, see Using compass during exercise.
