FREE SHIPPING OVER $350 | EASY RETURNS | GIFT OF THE WEEK | SIGN UP FOR NEWSLETTER
Suunto Tank POD User Guide
Installing Tank POD
Suunto recommends that the installation or removal of Suunto Tank POD is done by a Suunto authorized dealer or trained dive expert.
For your safety, use Suunto Tank POD with the provided Suunto Flow Restrictors.
Suunto Flow Restrictor Type A and Type B are included with your Suunto Tank POD. The shorter Flow Restrictor Type A is used when Suunto Tank POD is installed directly to a first-stage regulator high pressure port. The longer Flow Restrictor Type B is used when Suunto Tank POD is connected to a high pressure hose extension, with the hose attached to the first-stage regulator high pressure port.
The restrictor should only be removed for cleaning or changing scuba gear. The restrictor must be re-installed before using Tank POD again.
CAUTION:
Improper tool use and over tightening may damage scuba equipment. The recommended maximum torque is 8 Nm.
