FREE SHIPPING OVER $350 | EASY RETURNS | BOXING WEEK SALE
Suunto Tank POD User Guide
Unpairing Suunto Tank POD
For Suunto EON Core, EON Steel, and EON Steel Black
To unpair and remove your Suunto Tank POD from a specific gas using proximity:
  1. Hold your Suunto Tank POD close to your dive computer in Tank pressure view:
    image-Gas-menu-tankPOD-Eon2
  2. Gases menu opens. Select the gas you want to unpair your Suunto Tank POD from:
    Gas-menu-tankPOD Eon
  3. Select Unpair:
    Tankpod unpair Eon
  4. Your Suunto Tank POD is removed from the selected gas list:
    eon menu pairing select gas
    TankPOD-removed Eon
To unpair and remove your Suunto Tank POD from a specific gas through the menu:
  1. Select the gas you want to unpair the Suunto Tank POD from in the Gases menu:
    tank information
  2. Press the middle button to enter the gas settings and select Tank POD.
    eon menu unpairing assigned pod
  3. Select the Suunto Tank POD you want to unpair (check the serial number):
  4. Select Unpair:
    select unpair menu
  5. Your Suunto Tank POD is removed from the selected gas list:
    TankPOD-removed Eon
For D5
    TankPOD-gas-view
    TankPOD-proximity
  3. Press the upper button and select Unpair:
    TankPOD-proximity-unpair
    TankPOD-removed
    Gas-menu-tankPOD
    D5 menu unpairing select tankpod menu item
    Gas-menu-tankPOD-2
  4. Select Unpair:
    TankPOD-unpair
    TankPOD-removed
