To unpair and remove your Suunto Tank POD from a specific gas using proximity:
Hold your Suunto Tank POD close to your dive computer in Tank pressure view:
Gases menu opens. Select the gas you want to unpair your Suunto Tank POD from:
Select Unpair:
Your Suunto Tank POD is removed from the selected gas list:
To unpair and remove your Suunto Tank POD from a specific gas through the menu:
Select the gas you want to unpair the Suunto Tank POD from in the Gases menu:
Press the middle button to enter the gas settings and select Tank POD.
Select the Suunto Tank POD you want to unpair (check the serial number):
Select Unpair:
Press the upper button and select Unpair:
Select Unpair:
