Suunto Nautic S User Guide
Alarm clock
Your watch has an alarm clock that can sound once or repeat on specific days. Activate the alarm from the settings under Alarm clock.
To set a fixed alarm time:
  1. From the watch face, long press the lower button to access the Control panel.
  2. Select Alarm clock.
  3. Select New alarm.
    Older alarms can be deleted or edited if selected in the list below New alarm.
  4. Select how often you want the alarm to sound. The options are:
    Once: alarm sounds once in the next 24 hours at the set time
    Weekdays: alarm sounds at the same time Monday thru Friday
    Daily: alarm sounds at the same time every day of the week
    alarms Phoenix step2
  5. Set the hour and minutes and then exit the settings.
    alarms Phoenix step1
When the alarm sounds, you can dismiss it to end the alarm, or you can select the snooze option. The snooze time is 10 minutes and can be repeated up to 10 times.
Alarm dismiss snooze S9PP
If you let the alarm continue to sound, it will automatically snooze after 30 seconds.
Indice
