Planning routes with Suunto app in 3D helps you get a comprehensive understanding of what lays ahead – and reviewing your adventures in 3D can bring back great memories!
Music controls
With music controls on your wrist you can adjust the volume, pause and skip tracks. Connect your headset to your phone and off you go.
Burner
The Burner feature shows how fast you are burning grams of fat and carbohydrates while exercising. Helps in weight management and maintaining a healthy balance with diet and exercise. Feature available under SuuntoPlus™.
Adventure starts here
The heatmaps on Suunto app show the best places for running, cycling, swimming or skiing, etc. Plan your routes on the Suunto app, and store them in your watch for guidance along the way.
Enjoy the convenience of over the air software update via Suunto app, so that your watch always has the latest and greatest software.
*Available only for Suunto 9 Peak
Blood oxygen*
Check your acclimation for high altitude from the blood oxygen level.
The Suunto 9 Peak is not a medical device and is not intended for diagnosing or monitoring medical conditions.
Variometer*
The Variometer SuuntoPlus™ feature is a handy tool to keep track of your vertical speed. It helps the hike and fly community to see, feel and hear how fast they are climbing. Feature available under SuuntoPlus™.
*Available only for Suunto 9 Baro and Suunto 9 Peak
Turn-by-turn navigation
Never take a wrong turn again with turn-by-turn navigation alerts. Plan your route on komoot’s desktop or mobile app and sync it with your Suunto 9 to get started. When a turn is approaching, you’ll receive an alert so you can enjoy the scenery instead of focusing on your watch. Learn more about komoot.
Point of interest creation and navigation
A point of interest (POI) is an important location that you can save and navigate later to. Create POIs on your Suunto 9 by saving your current location, or add them in the Suunto app and sync them to your watch. When navigating towards a POI, you can see the direction and distance to the location. If you need to, you can easily switch between POI and route navigation when you're on the go.
‘Tour’ battery mode
Now you can enjoy even longer adventures with the new ‘Tour’ battery mode that gives you up to 7 days of continuous GPS tracking.
New outdoor partners
Plan your off-road adventures on komoot, find your next mountain adventure on FATMAP or check the best routes with Wikiloc. Suunto partners give you tools for your next trail run or mountain trip. Learn more at suunto.com/partners.
Update the Suunto 9 software to the latest version to receive the newest features and functionalities.
*실제 배터리 수명은 사용량과 조건에 따라 다를 수 있습니다. 울트라 배터리 모드를 사용할 경우, 배터리 수명은 증가되지만 손목 심박수 추적 기능은 정지됩니다. 엔듀어런스 배터리 모드에서, 배터리 수명은 손목 심박수의 경우 40시간이고 HR 벨트로는 50시간입니다. 운동 중에는 터치를 사용할 수 없지만 사용자 정의 모드에서 작동시킬 수 있습니다.
