Track your human-powered commutes with Suunto app. You can now tag your rides, runs, walks and other activities as "commutes" and learn how much CO2e emissions you have saved compared to driving that same distance.
Select the right trail for you
Whether you are a gravel, MTB or road cyclist, the new road surface information in Suunto app, allows you to plan your route exactly where it fits your bike and mood.
Just enable one road surface at a time or all options together to see paved, unpaved and rough paths.
See your routes in 3D
Planning routes with Suunto app in 3D helps you get a comprehensive understanding of what lays ahead – and reviewing your adventures in 3D can bring back great memories!
Music controls
With music controls on your wrist you can adjust the volume, pause and skip tracks. Connect your headset to your phone and off you go.
Burner
The Burner feature shows how fast you are burning grams of fat and carbohydrates while exercising. Helps in weight management and maintaining a healthy balance with diet and exercise. Feature available under SuuntoPlus™.
Adventure starts here
The heatmaps on Suunto app show the best places for running, cycling, swimming or skiing, etc. Plan your routes on Suunto app, and store them in your watch for guidance along the way.
Enjoy the convenience of over the air software update via Suunto app, so that your watch always has the latest and greatest software.
*Available only for Suunto 9 Peak
Blood oxygen*
Check your acclimation for high altitude from the blood oxygen level.
The Suunto 9 Peak is not a medical device and is not intended for diagnosing or monitoring medical conditions.
Variometer*
The Variometer SuuntoPlus™ feature is a handy tool to keep track of your vertical speed. It helps the hike and fly community to see, feel and hear how fast they are climbing. Feature available under SuuntoPlus™.
*Available only for Suunto 9 Baro and Suunto 9 Peak
Turn-by-turn navigation
Never take a wrong turn again with turn-by-turn navigation alerts. Plan your route on komoot’s desktop or mobile app and sync it with your Suunto 9 to get started. When a turn is approaching, you’ll receive an alert so you can enjoy the scenery instead of focusing on your watch. Learn more about komoot.
Point of interest creation and navigation
A point of interest (POI) is an important location that you can save and navigate later to. Create POIs on your Suunto 9 by saving your current location, or add them in the Suunto app and sync them to your watch. When navigating towards a POI, you can see the direction and distance to the location. If you need to, you can easily switch between POI and route navigation when you're on the go.
‘Tour’ battery mode
Now you can enjoy even longer adventures with the new ‘Tour’ battery mode that gives you up to 7 days of continuous GPS tracking.
New outdoor partners
Plan your off-road adventures on komoot, find your next mountain adventure on FATMAP or check the best routes with Wikiloc. Suunto partners give you tools for your next trail run or mountain trip. Learn more at suunto.com/partners.
Update the Suunto 9 software to the latest version to receive the newest features and functionalities.
Learn more about the media controls for your Suunto device.
Learn more about your training and the benefits of the SuuntoPlusTM Burner feature.
Learn more about managing your training load with Suunto app.
Turn-by-turn navigation powered by komoot
How do I use maps and routes with Suunto app?
SuuntoPlus™ - a solution that brings new features to your Suunto watch and enhances your experience.
장시간 트레이닝하는 동안 배터리 모드를 사용하고 배터리 수명을 연장시키는 방법에 대해 알아보세요.
본 비디오에서는 설정 메뉴에서 개인 페이스와 파워 영역을 설정하는 방법을 단계별로 보여줍니다.
이 동영상은 다음과 같이 단계별로 보여줍니다. 운동에 맞는 파워 목표를 활성화하는 방법. 운동하는 동안 목표 내에서 실시간 안내를 사용하는 방법.
이 동영상은 다음과 같이 단계별로 보여줍니다. 운동에 적합한 페이스 목표를 활성화하는 방법. 운동하는 동안 목표 내에서 실시간 안내를 사용하는 방법.
SuuntoLink를 사용하여 시계에 최신 소프트웨어를 설치하는 방법에 대해 알아보세요. SuuntoLink 다운로드
Learn more about using our digital services as a Suunto Spartan or Suunto 9 user.
Suunto 시계를 Suunto 앱 (iOS용)과 페어링하는 방법과 앱으로 시작하는 방법에 대해 알아보세요.
Suunto 시계를 Suunto 앱 (Android용)과 페어링하는 방법과 앱으로 시작하는 방법에 대해 알아보세요.
미지근한 물과 순한 비누로 시계를 정기적으로 청소하십시오.
*실제 배터리 수명은 사용량과 조건에 따라 다를 수 있습니다. 울트라 배터리 모드를 사용할 경우, 배터리 수명은 증가되지만 손목 심박수 추적 기능은 정지됩니다. 엔듀어런스 배터리 모드에서, 배터리 수명은 손목 심박수의 경우 40시간이고 HR 벨트로는 50시간입니다. 운동 중에는 터치를 사용할 수 없지만 사용자 정의 모드에서 작동시킬 수 있습니다.
