SUUNTO 7
The Smartwatch
for Sporty Life
Buy now
SUUNTO 7
Juggling a busy life with daily exercise can be tricky – you want a smartwatch sporty enough it can keep up with your active life everyday, seamlessly. Suunto 7 gives you the best of both worlds, and is designed to help you get the most out of your time. It’s our first watch that combines Suunto’s versatile sports experience with helpful smartwatch features from Wear OS by Google™.
Suunto 7 works with Android™ and iOS phones.
Fast Company’s 2020 Innovation by Design Awards in the Wellness category   Best of CES 2020 Finalist
Slide lift image Slide lift image mobile
New features for Suunto 7
Battery-saving GPS mode
Selecting 'Good' location accuracy makes the battery last longer during your outdoor workouts. Prepare for longer sessions or use it when you are already low on battery and want to keep going. When running or cycling, FusedTrack™ is used to improve tracking quality. Learn more about FusedTrack™
Learn more about Suunto 7’s battery here
Low power always-on sport display
Your display stays awake all the time while you exercise, using only a minimum amount of battery. This enables you to constantly see all your training data without having to raise your wrist to activate the display.
New Suunto 7 Graphite in a premium gift box
This limited holiday edition features a Suunto 7 Graphite with an ultra-soft microfiber textile strap that flexes perfectly around your wrist for a comfortable, breathable, and secure fit. The additional silicone strap in graphite color is easy to change without additional tools. The watch and the accessory strap are packaged in a beautiful dark gray holiday gift box, ready for that big festive surprise.
Route navigation
Create your own route, use tracks from other services or select a popular trail in the Suunto app. Sync the route to your watch and off you go! With route navigation on your watch you'll always find your way.​
Popular routes ​
Getting bored of running the same trails but not sure where to go? We made finding new routes easy for you by adding popular routes to the Suunto app. These routes are generated from the exercises of the Suunto community.
Popular starting points
When heading to a new place or route, it’s often hard to figure out where to start. Check out popular starting points in the Suunto app to easily know where to start your adventure from. The popular starting points are also visible with heatmaps on Suunto 7.​
My tracks
See your own personal heatmap with a daily, monthly, and current year view. You can also compare your tracks with the most popular routes for your sport.
New Suunto app homescreen
Improved Suunto app home page will give you direct access to your calendar, activity totals and map.
MyRadar
Quickly see what weather is coming your way with MyRadar. This app gives you real-time weather with local animated weather maps so you can plan your outdoor adventures. Read more about MyRadar.
New outdoor partners
Find your next trip from Sportihome, check the best routes with Wikiloc or view your tracks with Land. Suunto partners give you tools for your next trail run or mountain trip. Learn more from suunto.com/partners.
Adventure starts here.
Suunto equips you for your outdoor adventures – discover new trails, stay confident in the wilderness and train for longer explorations.
These new features and functionalities are available through the latest system update PXDZ.200824.005.
Learn more
Introducing Suunto 7
TRACKS YOUR SPORTS ACCURATELY
All the sports features of Suunto 7 are just one button press away. Track your exercise accurately with 70+ sports modes, GPS and wrist heart rate sensor. Quickly check your daily steps and calories on the watch. Easily share your exercises in the Suunto app or on major sport services like Strava, Endomondo and TrainingPeaks. You can also connect your headset to your phone and control music from your wrist.
Read more about Suunto app
AND IS READY FOR WHATEVER ADVENTURES YOU DECIDE TO TAKE ON.
Suunto 7 is designed and tested in Finland with the quality that Suunto is known for. Shock, water, and dirtproof, the watch works in rain, mud, or snow. It has physical buttons so you can use it with gloves on and its extremely bright high-resolution touch screen is protected with scratch-resistant Gorilla® Glass.
Suunto 7’s battery will give you a full day of smartwatch use and still have enough juice left for your daily workout. Alternatively, it can provide up to 48 hours of smartwatch use or up to 12 hours in GPS tracking mode.* Using the battery-saving GPS mode makes the battery last longer during your outdoor workouts. Prepare for longer sessions or use it when you are already low on battery and want to keep going.
MAKES YOUR EVERYDAY EASIER
When you’re not working out, you want convenient smartwatch features from a name you can trust. Suunto 7 is powered with Wear OS by Google, making this the smartest sports watch yet. Be informed by your favorite apps, see your next meeting or to-do list, easily check calls and quickly view incoming messages from your watch. Equipped with a faster, more secure way to pay from Google Pay™, smart help from Google Assistant and thousands of apps on Google Play.
Availability of Google Pay and Google Assistant varies by language and country.
Google apps
AND INSPIRES YOU TO EXPLORE.
Discover the world around you using the free offline maps with terrain details, trails and contour lines. It is easy to glance the maps at any time, and they are always one swipe away during exercise. Built-in heatmaps for 15 activities including running, swimming, and cycling show you the most popular routes so you can train where others have trained or choose to stay away from the beaten track. Local offline maps and heatmaps will be downloaded automatically when you’re connected to Wi-Fi and charging. You can also manually select the map of your preferred location to be downloaded. With offline maps you’ll always find your way and know the best training routes, even when you leave your phone behind or don’t have network connectivity.
THE WATCH GETS BETTER EVERY DAY
With Wi-Fi connectivity, software updates are automatic so your watch is always up to date and has the latest features. Extend watch functionalities with your favorite apps on Google Play and change the look of your watch with different watch faces and interchangeable straps.
AND GIVES YOU BENEFITS FROM OUR PARTNER NETWORK.
Connect your Suunto 7 with your favorite tools to analyze your activities, find new routes, get coaching or create 3D videos of your adventures – and share to your favorite communities. Suunto 7 also comes with Value Pack; benefits and treats worth over 500€/£/$ offered to you by our partners aiming to elevate your training and outdoor experience.
Learn more about Value Pack
See all partners
Suunto 7
신제품
Suunto 7
Graphite Limited Edition
Smartwatch with versatile sports experience, with 2 straps. Comes in a premium gift box.
제품 보기
Suunto 7
Black Lime
제품 보기
Suunto 7
Graphite Copper
제품 보기
Suunto 7
Sandstone Rosegold
제품 보기
Suunto 7
All Black
제품 보기
Suunto 7
White Burgundy
제품 보기
GET STARTED WITH YOUR SUUNTO 7
Get started
* Actual battery life may vary considerably depending on sports, settings, applications, and many other factors.
Google, Android, Google Play, Wear OS by Google, Google Pay and Google Fit are trademarks of Google LLC. Availability of Google Assistant and Google Pay varies by language, country and bank partner.
Learn more about Google Assistant Learn more about Google Pay
Wear OS by Google works with phones running the latest version of Android (excluding Go edition and phones without Google Play Store) or iOS. Supported features may vary between platforms and countries with compatibility subject to change.
