Set up
To start using your watch:
  1. Keep Start Stop pressed to wake up the device.
  2. Press Start Stop or Light Lock to scroll to the desired language and press Next to select.
select language
  1. Follow the startup wizard to complete initial settings. Set values with Start Stop or Light Lock and press Next to accept and go to the next step.
startup wizard Traverse
After completing the setup wizard, charge the watch with the supplied USB cable until the battery is fully charged.
connect USBcable
If a blinking battery symbol is displayed, Suunto Ambit3 Vertical needs to be charged before starting.
