Suunto 9 Peak User Guide
Adjusting settings
You can adjust all watch settings directly in the watch.
To adjust a setting:
  1. Swipe down until you see the settings icon and tap the icon.
Settings icon Spartan
  1. Scroll through the settings menu by swiping up or down or by pressing the upper or lower buttons.
Settings menu Spartan
  1. Select a setting by tapping the setting name or pressing the middle button when the setting is highlighted. Go back in the menu by swiping right or selecting Back.
  2. For settings with a value range, change the value by swiping up or down or by pressing the upper or lower button.
Backlight mode Spartan-1
  1. For settings with just two values, such as on or off, change the value by tapping the setting or pressing the middle button.
24hour time
You can also access general settings from the watch face by keeping the middle button pressed to open the shortcuts menu.
Do Not Disturb S9 Peak
