Suunto is committed to ensuring that this website achieves Level AA conformance with the Web Content Accessibility Guidelines (WCAG) 2.0 and achieving compliance with other accessibility standards. Please contact Customer Service at USA +1 855 258 0900 (toll free), if you have any issues accessing information on this website.
Find a dealer/service center
Using Foot POD
When using a foot POD, the POD is auto calibrated by GPS at short intervals during exercise. However, the foot POD always remains the source of speed and distance when it is paired and active for the given sport mode.
Foot POD auto calibration is on by default. It can be turned off in the sport mode options menu under Activate, if the Foot POD is paired and is used for the selected sport mode.
Foot POD refers to both Suunto Foot POD Mini and any other ANT+ foot POD.
For more accurate speed and distance measurements, you can manually calibrate the foot POD. Perform the calibration on an accurately measured distance, for instance, on a 400 meter running track.
To calibrate foot POD with Suunto Ambit2 S:
  1. Attach foot POD to your shoe. For more information, see user guide for the foot POD you are using.
  2. Choose a sport mode (for example Running) in the start menu.
  3. Start running at your usual pace. When you cross the starting line, press Start Stop to start the recording.
  4. Run a distance of 800–1000 meters (about 0.500–0.700 miles) at your usual pace (for example two laps on a 400 meter track).
  5. Press Start Stop when you reach the finish line to pause the recording.
  6. Press Back Lap to stop recording. After stopping the exercise, save the log by pressing Start Stop. If you do not want to save the log, press Light Lock. Scroll with Next through summary views, until you reach the distance summary. Adjust the distance shown on the display to the actual distance you ran with Start Stop and Light Lock. Confirm with Next.
  7. Confirm the POD calibration by pressing Start Stop. Your foot POD has now been calibrated.
If the foot POD connection was unstable during the calibration exercise, you might not be able to adjust the distance in the distance summary. Make sure that foot POD is attached properly according to instructions and try again.
If you are running without a foot POD, you can still get running cadence from the your wrist. Running cadence measured from wrist is used together with FusedSpeed and is always on for specific sport modes including running, trail running, treadmill, orienteering, and track and field.
If a foot POD is found at start of an exercise, running cadence measured from wrist is overwritten by foot POD cadence.
