Suunto Ocean User Guide
Dive logs
Dive logs can be found under the Logbook together with your other training activities.
Dives are listed by date and time, and each entry listing shows the max. depth and dive time of the log.
Selecting a dive, by pressing the middle button, provides you with a more detailed version. Dive log details and profile can be browsed by scrolling through the logs with the upper or the lower button and selecting a log with the middle button.
Each dive log contains data samples with fixed 10-second intervals. Freedive sample rate is 1 second.
The dive log contains the following data:
  • Dive time
  • Start and stop times
  • Average and max depth
  • An algorithm deviation alert if present during the dive
  • Maximum and average temperature
  • Gas list of active and enabled gases
  • Start and end pressure if linked with Suunto Tank POD
  • Avg gas consumption for each gas if linked with Suunto Tank POD
  • Current Gradient Factors
  • CNS and OTU values
  • Average heart rate if enabled
  • Surface time
When the logbook memory gets full, the oldest dives are deleted to make space for new ones.
