The Best Watch for Thru-Hiking: A Buying Guide for Long-Distance Hikers | Suunto
Sport watches — 31 July 2026
Quick answer: The best thru-hiking watch is one you can rely on for months at a time, far from an outlet. Prioritize battery life measured in months rather than days, a display you can read in bright sun and full dark, weather awareness that works off-grid, and durability that survives a full season on trail. A traditional ABC watch like Suunto Core 2 delivers all four, with up to 15 months on a single replaceable battery. If your trips run a day or two and you want turn-by-turn GPS navigation, Suunto Vertical is the better fit. Core 2 is built for the longer, more committed miles.
A thru-hike is a different kind of trip, and it asks different things of your gear.
A weekend in the hills forgives a lot. A five-month walk from Mexico to Canada forgives very little. Everything in your pack gets weighed, questioned, and often mailed home. The things that survive are the ones that keep earning their place, week after week, in heat and rain and cold, hundreds of miles from the next town.
Your watch is one of those things, if you choose it well. Here is what actually matters when you do.
Battery Life You Can Plan Around
This is the first question, and for most thru-hikers it is the deciding one.
On trail, power is a budget. Your phone is your camera, your map, your journal, and your lifeline, and it is already competing for space on your power bank. Every device you add is another draw on the same limited supply, and another thing to remember in town on a short resupply stop.
So think in terms of how often a watch needs your attention. A GPS smartwatch typically wants charging every few days to a couple of weeks, which means it lives on your charging rotation for the whole hike. A traditional ABC watch runs for months on a single cell, so it stays out of the rotation entirely and leaves your power bank free for the things that truly need it.
Suunto Core 2 runs for up to 15 months of typical use on a replaceable CR3032 cell. Set out in April, walk until October, and it is still going. A low-battery alert gives you fair warning in good time, and the battery is user-replaceable with a common cell you can pick up almost anywhere.
A Display You Can Read in Any Light
You will check your watch hundreds of times a day, for the time, your heading, your altitude, and the pressure, usually for a second at a time, and often in conditions that make screens difficult. Glare on an exposed ridge, flat gray light under cloud, the last hour of dusk, or a pre-dawn start under headlamp.
Look for high contrast and a display that stays legible whatever the conditions throw at it. Core 2 uses an LED dot-matrix display that is 40% brighter than the original Core, protected by Gorilla Glass. It reads cleanly in direct sun and stays sharp in poor light.
The backlight matters more than people expect. Core 2 gives you a switchable red and green backlight in one watch: green for high contrast in haze and low light, red to protect your night vision on early starts and night hikes, where a burst of white light costs you your dark-adapted eyes for several minutes. That is the kind of small thing you appreciate every single morning.
Weather Awareness That Works Off-Grid
The single most valuable thing a watch can tell a thru-hiker is that the weather is about to change while there is still time to do something about it.
Here is where the technology choice really matters. A connected smartwatch pulls a forecast from a network, so its usefulness depends on having a signal. On a long trail, that signal disappears for days at a stretch, and often exactly where the exposure is highest.
A barometric watch reads the air pressure directly, on your wrist. Core 2 tracks that pressure and follows the trend, and when it drops sharply, it sounds a storm alarm. That warning arrives whether or not there is a signal within a hundred miles. The sensors and the alarm are both more accurate this generation, with far fewer false alarms, so the warnings you get are ones you can act on.
Pair that with the altimeter, which shows your current elevation, and you have a genuine read on the mountain: how high you are, and what the air is doing. On an exposed section above treeline, that is the information that decides whether you push on or drop down.
Durability for a Full Season
A thru-hike is months of continuous abuse. Your watch will be scraped along granite, pushed through blowdowns and brush, rained on for days, frozen at altitude, and baked in the desert. It gets banged on trekking poles and slept in.
Look for a watch built to a durability standard rather than a marketing adjective. Core 2 is tested to MIL-STD-810H military durability standards for a wide range of extreme conditions, and it is water resistant to 10 ATM, which comfortably covers river fords, storms, and the swim at the end of a hot day.
Weight, Comfort, and Simple Operation
You will wear this thing for several months straight, so comfort is a real criterion, not a luxury. Core 2 keeps a refined version of the original’s shape, with a cleaner bezel curve and a better strap that sits comfortably through long days and long nights.
Operation matters just as much. Cold hands and gloves make touchscreens frustrating. A classic five-button layout, now with larger, more responsive buttons, gives you positive, tactile control you can work with numb fingers, in the dark, with gloves on, which is exactly when you need the information most.
Navigation: Be Honest About What You Need
This is where thru-hikers split, and the honest answer is that it depends on how you navigate.
Most long-distance hikers navigate with a phone app and downloaded offline maps, with paper as a backup. If that is you, a GPS watch is a nice-to-have rather than a necessity, and it comes at the cost of daily charging. What you want on your wrist is what your phone cannot give you when its battery runs low, or it is wet or buried in your pack: a bearing, your altitude, and the pressure trend. A lift of the wrist gives you your direction; a glance switches to your altitude and what the air is doing, so more of the trip feels within your control. That is a traditional ABC watch, and it is the case for Core 2.
If you want turn-by-turn navigation, route files, and full training metrics on your wrist, that is a different watch. Suunto Race and Suunto Vertical are built for exactly that, with full satellite navigation and long GPS battery life, and Vertical in particular is designed for multi-day mountain use. Choose that route with your eyes open, and plan your power budget around it.
The Short Version
For most long-distance hikers, the picture is simple: a loaded pack, trekking poles, an appetite for the unknown, and a watch that makes that unknown something you can read, one that runs for months, stays legible in any light, and warns you about the weather using its own sensors, signal or not.
That is precisely what Suunto Core 2 is built to do. Altitude, pressure, and direction, read from the world around you, in a watch that keeps going long after the trail town is behind you.
The unknown, made certain. Explore Suunto Core 2 at suunto.com.
Frequently Asked Questions
What is the best watch for thru-hiking?
The best thru-hiking watch has battery life measured in months, a display that reads in bright sun and full dark, off-grid weather awareness, and proven durability. Suunto Core 2 covers all four as a traditional ABC watch, with up to 15 months on a replaceable battery. For turn-by-turn GPS navigation, Suunto Vertical is the better fit.
Do I need a GPS watch for a thru-hike?
Most thru-hikers navigate using a phone with offline maps, so a GPS watch is optional. An ABC watch gives you altitude, a compass bearing, and storm warnings that work far beyond cell coverage and run for months on one battery, which complements your phone rather than duplicating it.
How long does Suunto Core 2 last on one battery?
Core 2 runs up to 15 months of typical use on a replaceable CR3032 cell, enough to cover an entire thru-hiking season. It is user-replaceable, and a low-battery alert gives you fair warning ahead of time.
Can a watch predict the weather on trail?
A barometric watch reads air pressure directly and tracks the trend, so a sharp drop signals worsening weather. Core 2 sounds a storm alarm when that happens, and because the reading comes from the watch itself, it works far outside cell coverage.
Is Suunto Core 2 tough enough for the PCT or AT?
Yes. Core 2 is tested to MIL-STD-810H military durability standards and is water resistant to 10 ATM, built for months of continuous use in rain, heat, cold, and rough terrain.
