SIGN UP FOR NEWSLETTER | EASY RETURNS
Suunto D5 User Guide
Gas time
Gas time refers to remaining air (gas) left with current gas mixture, measured in minutes. The time is based on the tank pressure value and your current breathing rate.
Gas time is also highly dependent on your current depth. For example, all other factors being the same, including breathing rate, tank pressure and tank size, depth affects gas time as follows:
  • At 10 m (33 ft, surrounding pressure 2 bar), gas time is 40 minutes.
  • At 30 m (99 ft, surrounding pressure 4 bar), gas time is 20 minutes.
  • At 70 m (230 ft, surrounding pressure 8 bar), gas time is 10 minutes.
Gas time can be viewed at the bottom of the dive mode screens. If you have not paired a Suunto Tank POD, the gas time field shows N/A. If you have paired a POD but there is no data being received, the field shows - -. This may be because the POD is not in range, the tank is closed, or the POD battery is low.
p23-gas-time
It is important to adjust tank size, tank pressure and personal gas consumption to get the gas calculations right. Find these options under Dive planner in the device menu.
