Suunto EON Steel User Guide 3.0
Dive modes
By default, Suunto EON Steel has four dive modes: Air/Nitrox, Trimix, CCR and Gauge (bottom timer). Select the appropriate mode for your dive under Dive settings » Mode.
dive modes eon steel
Suunto EON Steel shows all dive mode names in English. You can change dive mode names via Suunto app.
Air/Nitrox mode is by default in graphical style and all the others in classic visual style. You can change this and other settings, as well as create additional dive modes using Suunto app.
In Suunto app you can create new or edit existing dive modes, modify screen layouts, change helium and multi-gas settings, and change dive type (OC/CC).
The decompression algorithm used in Suunto EON Steel is Suunto Fused™ RGBM 2. For more information about the algorithm, see Decompression algorithm.
Air/Nitrox mode
By default, Air/Nitrox mode is for diving with regular air and diving with oxygen enriched gas mixtures.
Diving with nitrox gas mixture allows you to increase bottom times or reduce the risk of decompression illness. Suunto EON Steel provides you with information to adjust your dive and stay within safe limits.
When diving with nitrox gas mixture, both the percentage of oxygen in your tank and the oxygen partial pressure limit must be entered into Suunto EON Steel. This ensures correct nitrogen and oxygen calculations and the correct maximum operating depth (MOD), which is based on your entered values. The default oxygen percentage (O2%) setting is 21% (air) and oxygen partial pressure (pO2) setting is 1.6 bar (23 psi).
When diving with a nitrox gas mixture, Suunto recommends changing the partial pressure to 1.4 bar (20 psi).
Air/Nitrox mode has two views by default:
  • No deco
    no deco steel
  • Compass
    compass steel
After customizing in Suunto app, two other views are available:
  • Tank Pressure - For more information on what is shown on the display, see Tank pressure.
    TankPressView
  • Timer
    airnitrox timer view steel
Air/Nitrox dive mode has one active gas by default. You can edit this gas in the device menu where O2 percentage and pO2 value can be changed. To enable diving with more than one gas, you need to activate multi-gas diving under Dive settings » Parameters » Multiple gases. After this step you are able to add further gases in the Gases menu. Gas settings can also be customized in Suunto app.
Trimix mode
Trimix dive mode is for diving with a breathing gas consisting of oxygen, nitrogen and helium. With helium added, you can create gas mixtures optimal for your dive.
Trimix mode is typically for deep dives with extended dive time.
Trimix mode has two views by default:
  • No deco
    trimix nodeco view
  • Compass
    trimix compass view
  • Timer
In Trimix mode, Suunto EON Steel has the multiple gases option automatically turned on.
When diving with helium activated, deepstop is on by default, and it cannot be turned off.
CCR mode
CCR is a dive mode dedicated to rebreather diving.
When you select CCR mode, your device will have two different gas menus: CC gases (closed-circuit gases) and OC gases (open-circuit gases). For more information on diving in CCR mode, see Rebreather diving.
CCR mode has two views by default:
  • No deco
    ccr nodeco steel
  • Compass
    ccr compass steel
  • Timer
Gauge mode
Use Suunto EON Steel as a bottom timer with Gauge.
Gauge mode is a bottom timer only. It does not use any decompression algorithm, thus it does not include decompression information or calculations.
Gauge mode has two views by default:
  • Timer
    gauge default view
  • Compass
    Gauge compass eon
After customizing in Suunto app, a third view is available:
After diving in Gauge mode, decompression calculation is locked for 48 hours. If during this time you dive again in Air/Nitrox, Trimix or CCR mode, the dive algorithm and the decompression calculation will not be available and Locked will be shown on the screen.
Locked time is set back to 48 hours if you start a new dive while your device is locked.
