Suunto Core 2 vs Core 1: What’s New and Why It Matters
Sports — 21 heinäkuuta 2026
Quick answer: Suunto Core 2 refines the original Core with a brighter, higher-contrast LED dot-matrix display, a new switchable red and green backlight, upgraded 10 ATM water resistance, and Bluetooth connectivity for app syncing and updates. It adds a moon phase and a step counter, and it is built to MIL-STD-810H military standards. The ABC sensor suite (altimeter, barometer, compass) is carried forward and refined, and the long-life battery is still replaceable in the field with a coin. For Core 1 owners, the brighter display, the switchable backlight, and the tougher build make it a meaningful step forward.
The original Suunto Core is one of the most iconic outdoor watches ever made. Tough, analog in spirit, with a battery that lasted and a singular focus on the world in front of you. It told you where the weather was coming from. It told you how high you were. It pointed you north. For a lot of people, that was everything.
So when Suunto announced Core 2, the question was not simply what had changed. It was whether Suunto had kept faith with what made the original great. The answer is yes, and the upgrades that matter most are the ones you notice every single time you glance at your wrist.
A display built to be read
Start with the thing you look at a hundred times a day. Core 2 uses a high-contrast LED dot-matrix display that is 40% brighter than the original, now protected by tougher Gorilla Glass.
This is the upgrade Core 1 owners will feel first. Altitude at a glance on a bright ridgeline. A pressure trend read cleanly in flat, gray light. The numbers are larger, sharper, and easier to take in at speed, which is exactly what you want from a watch you check on the move rather than sit and study.
A backlight for every condition
New to Core 2 is a switchable backlight in two colors, and it is a genuine quality-of-life change. Choose the green backlight for high contrast in haze and low light. Switch to the red backlight to protect your night vision on a pre-dawn start or a long night in camp, where a bright white glow would cost you your dark-adapted eyes. One watch now handles every lighting scenario, something that once took a dedicated model to get red light at all.
It is a small feature with an outsized effect on how usable the watch is in the hours at the edges of the day, when you often need it most.
Battery: long-life, and still yours to replace
Battery life remains a Core hallmark. Core 2 runs for up to 15 months of typical use on a replaceable CR3032 cell, and, just like the original, the battery is user-replaceable, so a long-owned watch keeps going for years. A low-battery alert gives you fair warning in good time, so you can plan a fresh cell before it is needed. It is dependable, low-maintenance power that keeps working long after most watches would ask for a charger.
Tougher, and more at home in the water
Core 2 is built to MIL-STD-810H military standards, the benchmark used to validate gear against shock, vibration, temperature extremes, and moisture. Water resistance climbs to 10 ATM, comfortably clearing rain, river crossings, and swimming.
The message is simple: this is a watch engineered for the environments where equipment gets tested, and for the people who test it.
New tools: moon phase and step counting
Two additions round out the everyday experience. A moon phase display helps you plan night hikes, camp setups, and hunts around natural light. The step counter adds a simple, everyday measure of your activity. Both are quiet additions that leave Core 2's focus on the outdoor essentials fully intact.
Connectivity: Bluetooth, for the first time
The original Core worked everything out on its own. Core 2 adds Bluetooth Low Energy, a considered addition that brings real utility while keeping the watch's focused character intact.
Bluetooth pairs Core 2 with the Suunto app for settings sync, over-the-air firmware updates, automatic time and sunrise and sunset data, and activity export. It is connectivity as a tool: your data comes off the watch cleanly, and the watch stays fixed on the task in front of it.
Core watches are built to last, and many first-generation owners are still wearing theirs close to a decade on. Those over-the-air updates mean a watch you keep for years stays current the whole time.
What has stayed the same, and should have
Core 2 is still, first and last, an ABC watch. The altimeter, barometer, and compass remain at the center of the experience, refined rather than reinvented, with a noticeable step up in sensor accuracy. Real-time altitude and pressure, weather trends, and sunrise and sunset times are all present and all sharpened, and the storm alarm is more accurate too, giving you more dependable warnings you can trust and far fewer false alarms.
Suunto has kept Core 2 focused on reading the outdoors and keeping you oriented off-grid, rather than reaching for multisport modes or smartwatch features. The identity is intact, and that restraint is the point.
Worth the upgrade?
If you own a Core 1, yes. The brighter LED display and the switchable backlight change how you read the watch every day. The jump to 10 ATM and MIL-STD-810H makes it tougher and more water-ready. And the moon phase, step counter, and Bluetooth add real utility, all while keeping everything that made the original great.
If you are new to Suunto, Core 2 is a clear answer to a simple question: what is the best outdoor ABC watch you can buy?
Suunto Core 2 launches in July 2026. Explore the full spec at suunto.com.
Frequently asked questions
Is Suunto Core 2 worth upgrading from Core 1?
Yes. Core 2 brings a brighter, higher-contrast LED dot-matrix display, a new switchable red and green backlight, an upgraded ABC sensor suite, 10 ATM water resistance, MIL-STD-810H durability, a moon phase, a step counter, and Bluetooth connectivity. For Core 1 owners, the display and backlight upgrades alone change the daily experience.
What battery does Suunto Core 2 use?
Core 2 uses a replaceable CR3032 coin cell that lasts up to 15 months in typical use and is user-replaceable, with a low-battery alert to give you fair warning ahead of time.
Does Suunto Core 2 have GPS?
Core 2 is an ABC watch (altimeter, barometer, compass) built for off-grid essentials rather than GPS tracking. For built-in GPS navigation, Suunto Race or Suunto Vertical are the right choices.
Is Suunto Core 2 waterproof?
Core 2 is water resistant to 10 ATM, suitable for swimming, wading, and heavy rain.
