Suunto 7 User Guide
Customize watch faces
Suunto 7 comes with a set of pre-installed watch faces to choose from. You can also download many others from Google Play Store.
All watch faces designed by Suunto are optimized to use a minimum amount of power to provide you with the best possible day-to-day experience with your watch.
Suunto watch faces
Change your watch face
Add functions (or 'complications') to your watch face
Add a new watch face
Hide a watch face
Delete a watch face you found in the Play Store
Suunto watch faces
Suunto 7 comes with four watch faces by Suunto – Heatmap, Original, Marine and Rose – to celebrate the history of Suunto and the community of passionate athletes and adventurers around the world.
Heatmap
suunto-watchface-heatmap
To inspire and encourage you to explore the outdoors around you, the Heatmap watch face shows where other passionate Suunto athletes have been exercising in your area.
By default, the heatmap will show popular running routes in your area. If running is not your thing, you can go to the watch face settings and choose another sport for your heatmap. Suunto 7 has 15 different heatmaps to choose from.
The heatmap on your watch face is automatically updated based on your location. If you do not see a heatmap or the map does not update based on your location, check these:
  • On your phone, allow location sharing for Wear OS by Google.
  • On your watch, allow location sharing in Connectivity settings settings and in Suunto watch faces application permission settings.
  • Make sure your watch is connected to the Internet.
  • You have moved more than 2 kilometers (1.25 miles) from your previous location.
  • Try a different heatmap – maybe there is no heat for the sport you chose yet.
Original
suunto-watchface-original
In 1936, Tuomas Vohlonen founded Suunto to mass produce stable and accurate compasses after he had long been bothered by the inaccuracy and lack of steady needle operation of traditional dry compasses. Ever since, the Suunto compasses and connected Suunto method have provided essential tools for navigation for outdoor enthusiasts, athletes and professionals. The Original watch face design is inspired by the very first Suunto marching compass, M-311.
Marine
suunto-watchface-marine
Between 1953 and 2011 Suunto was in the marine compass market. The Marine watch face is inspired by the popular Suunto K-14 marine compass, which became a standard in a large number of sail and power boats around the world due to the stable and easy to read compass card and the smart mounting into the vessel.
Rose
suunto-watchface-rose
The Rose watch face is inspired by the Suunto pocket TK-3 compass which was inspired by old marine compasses with compass roses. TK-3 compass was a tribute to the endeavors of explorers filling out the whites of the world atlas using a compass, the stars and ropes as their main means of position finding.
You can change your watch face at any time to match your goals, needs and style.
wear-os-watchface-list
  1. While on the watch face, touch and hold the middle of the screen to see a list of watch faces.
  2. Swipe left or right to browse watch faces.
  3. Tap to select a watch face you want to use.
You can also go to Settings » Display » Change watch face or change your watch face in the Wear OS by Google app on your phone.
With most watch faces, you can add additional functions to your watch face, such as shortcuts to apps, weather information or daily steps. Different watch faces may have a different set of complications available.
  2. Tap Settings at the bottom of a watch face.
wear-os-watchface-settings
  1. Tap the ‘complication’ on the watch face design that you would like to change.
wear-os-watchface-complications
  1. Browse the list and tap to choose which complication you want to see on your watch face. (To add a shortcut, tap General » App shortcut.)
All watch faces designed by Suunto are optimized to use a minimum amount of power to provide you with the best possible day-to-day experience. When you add a new watch face from Google Play Store, keep in mind that other watch faces might not be optimized the same way.
  2. Swipe left and tap the option to add more watch faces.
  3. Scroll down and tap Get more watch faces. (If necessary, follow guidance to connect to Wifi and add a Google account.)
Hide a watch face
  2. Swipe up on the watch face that you want to hide.
When a watch face is hidden, you will see it in the Wear OS by Google app on your phone, but not on your watch.
  1. To open your list of apps, press the Power button.
  2. Tap the Play Store app PlayStore icon Wear OS.
    (If necessary, follow the instructions to connect to Wifi and add a Google account.)
  3. Scroll down and tap My appsMyApps icon Wear OS.
  4. Scroll down to the watch face you want to remove and choose Uninstall .
You can also manage your watch faces in the Wear OS by Google app on your phone. Under the image of your watch, next to watch faces, tap More.
Indice
