Suunto Race S vs Race 2: How to Choose
SuuntoRun — 31 Awwissu 2026
Put Suunto Race S and Suunto Race 2 side by side and the spec sheets look almost identical: bright AMOLED display, free offline maps, 115+ sport modes, and the same Suunto training and navigation tools. So which one belongs on your wrist-
The honest answer is that you’re not choosing between a better and a worse watch. You’re choosing between two different fits. Race S is the smaller, lighter watch that disappears into everyday wear. Race 2 trades some of that lightness for a bigger screen, roughly double the battery life, and tougher materials. Here’s how to work out which trade-off suits you.
At a glance
  • Suunto Race S: 45 mm case, 60 g in stainless steel or 53 g in titanium, 1.32″ AMOLED display. The pick for smaller wrists, daily wear, and runners who want a watch they stop noticing.
  • Suunto Race 2: 49 mm case, 76 g in stainless steel or 65 g in titanium, 1.5″ LTPO AMOLED display with sapphire crystal and 100 m water resistance. The pick for long races, trails, and anyone who reads their watch on the move.
  • Battery: Race S runs up to 9 days in smartwatch mode and 30 hours in the most accurate GPS mode. Race 2 stretches that to 18 days and 55 hours.
We've summarized the key details so you can get up to speed on each watch, head to head:
The short answer: which one fits you?
Choose Suunto Race S if you:
  • have a smaller wrist, or find most performance watches bulky
  • want one watch for training, work, sleep tracking, and everything in between
  • mostly run, train, and race at distances where 30 hours of GPS is plenty
  • value comfort during long sessions more than a bigger display
Choose Suunto Race 2 if you:
  • want a large, bright screen you can read at a glance mid-effort
  • train long: ultras, big trail days, multi-hour rides, or back-to-back sessions
  • would rather charge your watch every two weeks than every few days
  • put your gear through enough that sapphire crystal and 100 m water resistance matter
If you’re still torn after that, the differences below are the tiebreakers. The features you may be worried about losing (maps, sport modes, training analysis) exist on both.
Race S vs Race 2: full comparison table
Specification Suunto Race S Suunto Race 2
Case size 45 × 45 × 11.4 mm 49 × 49 × 12.5 mm
Weight 60 g stainless steel / 53 g titanium 76 g stainless steel / 65 g titanium
Display 1.32″ AMOLED 1.5″ LTPO AMOLED
Resolution 466 × 466 466 × 466
Glass Gorilla Glass Sapphire crystal
Water resistance 50 m 100 m
Offline map storage 32 GB 32 GB
Battery, smartwatch mode Up to 9 days Up to 18 days
Battery, all-systems GNSS + multiband Up to 30 hours Up to 55 hours
Battery, all-systems GNSS + single band Up to 40 hours Up to 65 hours
Battery, power-saving GNSS mode Up to 120 hours Up to 200 hours
Strap width 22 mm 22 mm
Same resolution, same map storage, same straps. The real separation is in four places: size and weight, display, battery, and durability. Let’s take them one at a time.
Size and weight: the difference you feel all day
This is the difference you’ll notice before you’ve tracked a single run. Race S has a 45 mm case and weighs 60 g in stainless steel or 53 g in titanium. Race 2 steps up to 49 mm and 76 g in steel or 65 g in titanium, and it’s about a millimetre thicker.
On paper that gap looks small. On the wrist, it compounds. A watch you wear for training, work, and sleep is on your arm more than twenty hours a day, and a lighter, slimmer case is simply easier to forget about, especially on smaller wrists or during arm swing on long runs.
The flip side: the larger case is what buys Race 2 its bigger display and bigger battery. If your wrist carries it comfortably, the extra grams are doing real work.
Display: 1.32″ AMOLED vs 1.5″ LTPO AMOLED
Both displays are sharp, colorful AMOLED panels with the same 466 × 466 resolution, so neither watch feels low-rent. The difference is area and technology.
Race 2’s 1.5-inch panel gives you meaningfully more room for data fields and maps, which matters most in the moments when you can only spare a glance: checking pace mid-interval, reading a junction on a descent, keeping an eye on heart rate in a race. Its LTPO panel can also dial its refresh rate down when showing static content, which is part of how a bigger, brighter screen still delivers double the battery life.
Race S’s 1.32-inch display shows the same data and the same maps, just in a more compact frame that matches its smaller case. For daily training it’s entirely sufficient; it’s only at high speed or deep into fatigue that the extra screen real estate on Race 2 starts to earn its keep.
Battery life: a week versus two and a half
This is the widest gap between the two watches, and for long-distance athletes it may settle the decision on its own.
Race S runs up to 9 days in smartwatch mode and up to 30 hours in the most accurate GPS setting (all-systems GNSS with multiband). That covers a full marathon build — daily training, sleep tracking, and a long weekend run — on a charge a week, and even a 100 km trail race for most finishers.
Race 2 roughly doubles everything: up to 18 days in smartwatch mode, 55 hours in the most accurate GPS mode, and up to 200 hours in power-saving GNSS mode. That’s ultra territory, multi-day trekking territory, and forget-your-charger-for-a-week territory.
A simple way to frame it: if your longest efforts finish under 30 hours, Race S covers you. If you’re eyeing races or adventures beyond that, or you just hate charging things, Race 2 is the safer bet.
Durability: sapphire crystal and 100 m water resistance
Race 2 is the tougher watch. It pairs sapphire crystal — significantly more scratch-resistant than glass — with 100 m water resistance. Race S uses Gorilla Glass and is rated to 50 m.
For running, gym work, and swimming, both are more than durable enough; 50 m water resistance handles pool and open-water sessions without complaint. Race 2’s advantage shows up at the rougher edges: scraping past rock on technical trails, seasons of daily wear without a screen protector, and water sports where a higher rating brings peace of mind.
Heart rate and running form: where Race 2 digs deeper
Both watches support Suunto’s core training metrics, including pace, heart rate, and distance tracking for reliable everyday performance.
Race 2 builds on the same tracking foundation with refinements in sensor performance and additional running form metrics such as stride and ground contact time.
Race S delivers consistent core tracking for everyday training, focusing on reliable data across key running metrics.
What both watches share
It’s worth repeating, because it’s the part most comparison shoppers get wrong: choosing the smaller, less expensive Race S does not mean giving up the core Suunto experience. Both watches include:
  • Free offline maps with 32 GB of storage, so you can navigate in the mountains with no phone signal
  • The April 2026 maps and navigation update: smart turn-by-turn guidance, climb guidance with zoom control, map labels, track back, and customizable map fields (see “New Maps & Navigation Updates Now Rolling Out”)
  • 115+ sport modes covering running, trail, cycling, swimming, and more
  • Race tools including race pacer and race time prediction
  • Dual-band GPS for accurate tracking in cities, forests, and mountains
  • Heart rate, sleep, HRV, and recovery tracking around the clock
  • Suunto Coach and full training analysis, free in the Suunto app
Whichever model you pick, the training experience, the metrics, the maps, the analysis, is the same. Effectively, you're choosing hardware, not features.
What if you mostly hike or go multi-day?
Race 2’s battery and durability make it a capable mountain watch, and for most trail runners it’s the natural pick of the two. But if your calendar leans toward trekking, expeditions, or multi-day mountain trips rather than training and racing, look at Suunto Vertical 2 as well. It’s built specifically for extended time outdoors. The comparison in “ Suunto Vertical 2 vs Race 2” covers that decision in detail.
Frequently asked questions
Which is better for running, Suunto Race S or Race 2?
Both are excellent running watches with identical training features. Race S suits daily running and everyday wear thanks to its lighter, more compact build. Race 2 is the better pick if you race long, want a bigger screen for mid-run glances, or need more than 30 hours of GPS.
Which model is better for smaller wrists?
Race S. Its 45 mm case and 53–60 g weight sit comfortably on smaller wrists, where the 49 mm Race 2 can feel oversized.
How much longer does the Race 2 battery last?
Roughly double across the board: up to 18 days versus 9 in smartwatch mode, and up to 55 hours versus 30 in the most accurate GPS mode.
Do both models have offline maps?
Yes. Race S and Race 2 both include free offline maps with 32 GB of storage, plus the full turn-by-turn and climb guidance features from the April 2026 navigation update.
Which is better for hiking and trail running?
For trail running, pick by priority: Race S for lightness, Race 2 for screen, battery, and durability. If multi-day hiking or trekking is your main focus, consider Suunto Vertical 2 instead.
The takeaway
Suunto Race S and Race 2 run the same software, track the same 115+ sports, and navigate with the same free offline maps. The decision comes down to hardware: Race S is the light, compact watch that’s effortless to wear every day, while Race 2 brings a larger LTPO AMOLED display, up to 55 hours of GPS, sapphire crystal, and 100 m water resistance for long races and hard use.
Pick the one that matches your wrist and your longest days. Either way, the training tools are all there.
Explore Suunto Race S and Suunto Race 2 to find the fit for your next season.
