FREE SHIPPING OVER NOK 1500  | EASY RETURNS | SIGN UP FOR NEWSLETTER
How do I restart my Suunto 7 watch?
Restart your watch
To restart your watch, you can press the Power button.
  1. Press and hold the Power button until the Power off/Restart screen is visible.
  2. Tap Restart.
Note: Google Assistant will show first when you press the Power button.
Or go to the settings:
  1. While on the watch face, swipe down from the top of the screen.
  2. Tap SettingsSettings icon Wear OS » System » Restart.
  3. Confirm your selection by tapping Checkmark icon Wear OS
Reset your watch to factory settings
If you're having problems with your watch, you may need to reset to its original settings.
When you reset your watch to factory settings the following actions happen automatically:
  • Data stored on your watch is erased. (including your exercises)
  • Installed apps and their data are erased.
  • System settings and preferences are erased.
  • Your watch is unpaired on your phone. You'll need to pair your watch with your phone again.
Note: Always remember to sync (and save) your exercises to Suunto mobile app on your phone. If you need to reset your watch, all unsynced exercises in the Diary will be lost.
  2. Tap SettingsSettings icon Wear OS » System » Disconnect and reset.
  3. Confirm your selection by tapping Checkmark icon Wear OS.
Set up and pair after a factory reset
If you are pairing your watch with an iPhone, you need to manually remove your Suunto 7 from the list of paired Bluetooth devices on your phone’s Bluetooth settings after a factory reset. Then you can set and pair your watch with the Wear OS by Google app on your phone.
Note: To reconnect your watch with Suunto mobile app on your phone, you first need to forget the watch in Suunto mobile app, then reconnect.
suunto-mobile-app-forget-watch
READ MORE:
