SIGN UP FOR NEWSLETTER | EASY RETURNS
Suunto D5 User Guide
Device setup
To get the most out of your Suunto D5, use some time to customize features and dive views. Make absolutely sure that you know your computer and have it set up as you want before getting into the water.
To get started:
  1. Wake up the device by connecting the USB cable to a PC/Mac or a power source. Use a USB port of 5 Vdc, 0.5A.
    p8-connect-cable
    p8-startup
  2. Follow the startup wizard to set up the device. When ready, the device goes to surface state.
    p8-device-ready
    Startup done D5
  3. Fully charge before first dive.
The startup wizard guides you through:
  • Language
  • Units
  • Time format (12h/24h)
  • Date format (dd.mm / mm/dd)
  • Time and date
  • Connecting to Suunto app (recommended)
