SIGN UP FOR NEWSLETTER | EASY RETURNS
Suunto Vyper Novo User Guide
Changing strap to bungee
Use the optional bungee adapter to change between wrist strap and bungee cord as needed.
To install the bungee:
  1. Turn the dive computer over.
  2. Remove each strap by depressing one end of the spring bar with a small flat-head screwdriver or spring bar removal tool.
  3. Attach the bungee adapters to each side of the case with the spring bars. Ensure the spring bars are firmly in position by pushing down on each end of the bar.
  4. Thread the bungee cord through the adapters and securely tie the ends.
  5. Pull hard on the bungee to ensure the adapters are in position and the cord knot is tight.
