SIGN UP FOR NEWSLETTER | FREE RETURNS
Suunto D5 User Guide
Tank pressure
Your Suunto D5 can be used with the total number of three Suunto Tank PODs for wireless tank pressure transmission.
To install and pair a Suunto Tank POD, see How to install and pair a Suunto Tank POD.
In tank pressure view, you can see the below screens.
In the switch window, the actual tank pressure is shown in a blue field by default. This is also shown with a blue arrow in the arch. The blue part of the arch indicates the range between the value you set for the tank pressure alarm and the actual tank pressure:
Tank Pressure No alarm D5
The following example has the tank pressure alarm set to 100 bars. The tank pressure is 75 bars as indicated in the switch window at the bottom.
When the tank pressure alarm is turned on and the value is between the value you set and 50 bars, the tank pressure value is indicated in a yellow field in the switch window and the range is also shown in the arch with yellow:
Tank Pressure Alarm D5
When the tank pressure drops below 50 bars (so within the red area in the arch) the actual tank pressure value is indicated in a red field in the switch window and a mandatory alarm is triggered:
Tank Pressure red Alarm D5
