To install and pair a Suunto Tank POD:
After a few seconds, a menu pops up on the screen showing the Tank POD serial number, battery status and the tank pressure. From the menu, select the correct gas for that Tank POD.
The battery level indication shown when pairing the Tank POD is an approximation only.
Alternatively you can pair the Suunto Tank POD(s) from the menu:
Select which Tank POD to use with each gas by selecting a Tank POD for the gas in question in the Gases menu.
In the dive main views, only one tank pressure is shown and corresponds to the active gas. When the gas is changed, the displayed tank pressure is also changed accordingly.
If there are several divers using Tank PODs, always check before you dive that the POD number of your selected gas corresponds to the serial number on your POD.
Remove pressure from the Tank POD when not diving to save battery life.
To unpair and remove your Tank POD from a specific gas through the menu:
Select the gas you want to remove the Tank POD from in the Gases menu:
Select the Tank POD you want to remove (check the serial number):
Select Unpair:
Your Tank POD is removed from the selected gas list:
To unpair and remove your Tank POD from a specific gas using proximity:
Hold your Tank POD close to your dive computer in Tank pressure view:
Scroll to the gas you want to remove your Tank POD from:
Select Unpair:
