NEW! WE NOW SHIP TO MALAYSIA| FREE SHIPPING OVER RM1000 | EASY RETURNS | SIGN UP FOR NEWSLETTER
How do I get the most out of the Suunto 9 battery modes?
Suunto 9 provides three predefined battery modes – Performance, Endurance and Ultra. When starting an exercise, the Performance mode is activated by default. If you define a custom battery mode, the custom mode will be activated by default. You can quickly switch modes by pressing the upper right button while in the exercise start display.
The battery modes have the following settings which can be viewed below the exercise start display, under Options > Battery modes. Here you can as well create a custom battery mode for the sport mode you selected.
Note: Custom battery modes are always specific for one sport mode. This means you can define a separate custom mode for each sport.
Battery mode Performance  Battery mode Endurance  Battery mode Ultra  Custom battery mode
To better understand the battery saving concept of your Suunto 9 – especially for setting a custom mode – we created a list of settings and features with their impact on battery life:
High impact on battery life
  • GPS accuracy Best
    To save battery: Set accuracy to Good.
Medium impact on battery life
  • GPS accuracy Good or OK
  • Display always on.
    To save battery: Set a Display timeout after 10 seconds.
  • Display in full color mode.
    To save battery: Activate Low color mode.
  • Wrist HR on.
    To save battery: Use a chest HR belt.
Note: You will find an additional Heart rate setting in the Options menu (see screenshot below). When deactivating this heart rate setting (toggle is grey) no heart rate will be measured.
Options menu
Small impact on battery life
  • Touch on.
    To save battery: Disable touch display.
Additional battery saving tips:
  • Backlight ON has a high impact on battery life.
    To save battery: Set the Backlight toggle to normal (toggle is grey) in the Options menu.
  • Low surrounding temperatures may shorten the battery life of your watch.
RELATED ARTICLES
FIND MORE SUPPORT FOR:
