Your Suunto Run has a battery power management system that uses intelligent battery technology to help ensure your watch does not run out of power when you need it most.
Before you start recording an exercise (see Recording an exercise) you see an estimate of how much battery life you have left in the current battery mode.
There are three predefined battery modes; Performance (default), Endurance and Power saving. Changing between these modes will change the lifetime of the battery but also changes the performance of the watch.
While in the start display, scroll down and select Exercise settings > Battery mode to change battery mode and see how each mode affects the performance of the watch.
In addition to the battery modes, your watch uses smart reminders to help you ensure you have enough battery life for your next adventure. Some reminders are preemptive based on, for example, your activity history. You also get notified, for example, when the watch notices you are running low on battery while recording an activity. It will automatically suggest changing to a different battery mode.
Only use the provided charging cable when charging your Suunto Run.
