Set up
To start using your watch:
- Keep Start Stop pressed to wake up the device.
- Press Start Stop or Light Lock to scroll to the desired language and press Next to select.
![select language](select-language.png)
- Follow the startup wizard to complete initial settings. Set values with Start Stop or Light Lock and press Next to accept and go to the next step.
![startup wizard Traverse](startup-wizard.png)
After completing the setup wizard, charge the watch with the supplied USB cable until the battery is fully charged.
![connect USBcable](connect-usbcable.png)
If a blinking battery symbol is displayed, Suunto Ambit3 Vertical needs to be charged before starting.
