Aerobic Threshold: Are You Training at the Right Intensity?
SuuntoRun — 14 settembre 2026
Endurance performance depends on how well your body keeps producing energy over time. Speed and training hours matter, but so does the efficiency that lets you hold an effort mile after mile.
You may already track VO₂ max, lactate threshold, and heart rate zones. Aerobic threshold (AeT) is another useful measure, and one that often gets overlooked. Knowing yours helps you plan low-intensity training, build endurance for longer efforts, and keep each workout at the right intensity.
At a Glance:
  • Aerobic threshold is a key physiological marker of aerobic fitness in endurance athletes.
  • Testing and training data can help estimate your aerobic threshold heart rate and guide workout intensity.
  • Training to develop your aerobic threshold can improve your ability to use fat as fuel and support endurance over time.
  • Aerobic threshold, lactate threshold, anaerobic threshold, and VO₂ max describe different aspects of fitness.
  • Suunto training data can help you follow changes in aerobic fitness and refine your training over the long term.
What Is Aerobic Threshold?
Aerobic threshold (AeT) helps define the upper end of low-intensity endurance exercise. It is generally associated with the first lactate threshold (LT1) or the first ventilatory threshold (VT1). LT1 is identified from changes in blood lactate as exercise intensity rises, while VT1 is identified from changes in breathing and gas exchange. Because the tests measure different responses, the results do not always line up exactly.
Below your aerobic threshold, your body can get a relatively large share of its energy from fat while using less glycogen. As intensity rises above AeT, it gradually relies more on carbohydrates, including stored glycogen, to meet the higher energy demand. Fatigue also begins to build more quickly.
AeT is not a fixed switch between fat and carbohydrate use, and crossing it does not mean your body suddenly relies mainly on anaerobic energy production. Your body's energy systems work together during exercise, and lactate is produced even when oxygen is available.
Why Does Aerobic Threshold Matter?
For endurance athletes, aerobic threshold is a useful indicator of aerobic fitness. As it improves, you can sustain a stable aerobic effort at a higher intensity and use fat and carbohydrates more effectively to meet your energy needs.
  • In practice, that means you can produce more speed or power during low-intensity training. After a period of consistent training, for example, you might run faster at the same heart rate in similar weather, on a similar route, and with a similar level of freshness. That can be a sign of better aerobic performance. It is less useful for comparing one athlete with another: maximum heart rate, thresholds, and running economy vary between people, so pace at a given heart rate cannot tell the whole story.
  • Developing your aerobic threshold can also help you hold a steady output at higher intensities and use fat more effectively as fuel. That helps spare your limited glycogen stores during long efforts and delay fatigue. These adaptations are especially valuable for marathons, trail running, and triathlons, where you need to sustain your effort for hours.
  • AeT also gives you a practical reference for planning training. Using your individual threshold as a guide to the upper limit of easy work helps you build aerobic volume without adding unnecessary fatigue, leaving more room to recover before your next session.
road running with Suunto watches
Aerobic Threshold vs. Anaerobic Threshold, Lactate Threshold, and VO₂ Max
Aerobic threshold, lactate threshold, anaerobic threshold, and VO₂ max all come up in endurance training. Each describes a different aspect of how your body handles exercise.
  • Aerobic threshold reflects your aerobic base and your ability to sustain an effort over time. It is commonly used to help define the range for low-intensity aerobic training.
  • Lactate threshold describes a threshold identified from changes in blood lactate. Its meaning depends on the definition and test being used. LT1 is closely related to AeT. The second lactate threshold (LT2) occurs at a higher exercise intensity.
  • Anaerobic threshold usually refers to an intensity near LT2 or the second ventilatory threshold. It marks the region where you are approaching the limit of your ability to sustain a hard effort. Above it, lactate accumulates more rapidly and the time you can keep going becomes limited.
  • VO₂ max is the maximum rate at which your body can take in, transport, and use oxygen during maximal exercise. It reflects the upper limit of your cardiorespiratory capacity, but it does not directly tell you what race intensity you can sustain. Even a high VO₂ max may not translate into strong endurance performance if your lactate threshold and aerobic base are underdeveloped.
What Is a Good Aerobic Threshold?
There is no single number that makes an aerobic threshold 'good.' Age, fitness, sport, training history, and your current physical condition all influence it.
For context, research has reported VT1, a marker associated with AeT, at around 50–60% of VO₂ peak. Treat that as a broad reference rather than a target. Results vary with training status, test methods, and individual physiology. Well-trained endurance athletes can generally sustain a stable aerobic effort at higher intensities.
What matters in training is knowing which physiological threshold your threshold heart rate represents. That helps you set appropriate heart rate zones and manage intensity more accurately. Alongside how the effort feels, look at long-term changes in heart rate, pace, and power under similar conditions to assess whether your aerobic fitness is improving.
How to Determine Aerobic Threshold
You can assess aerobic threshold in a lab or estimate it in the field. Lab tests use blood lactate or gas exchange data to identify physiological turning points. Field methods use cues such as your ability to talk, heart rate, and pace to guide training intensity. Results can differ between methods, so use the same approach and similar conditions when tracking changes over time.
1. Laboratory Assessment: Lactate and Gas Exchange Testing
  • Lactate Testing
Lactate testing measures blood lactate as exercise intensity increases in stages. The first clear change in the lactate curve can help estimate aerobic threshold.
In some protocols, LT1 may occur at a blood lactate concentration of around 1.5–2.0 mmol/L, but there is no single concentration that defines the threshold for everyone.
  • Gas Exchange Testing
Gas exchange testing, performed during a cardiopulmonary exercise test (CPET), measures oxygen uptake, carbon dioxide production, and breathing patterns as exercise intensity increases. These measurements help identify physiological markers such as VT1.
By measuring respiratory and metabolic responses directly, CPET provides a detailed assessment of aerobic fitness. It requires specialized equipment and a controlled testing environment.
threshold test in Suunto lab
2. Field Estimation: Practical Methods for Everyday Training
The MAF method combines a training heart rate guideline with a repeatable way to track performance. The MAF 180 Formula starts with 180 minus your age, then adjusts for health and training history. The result provides a suggested training heart rate, rather than a direct measurement of your aerobic threshold.
The MAF Test tracks pace, speed, or power at a chosen heart rate. Repeating it over time can help you monitor progress, but changes in performance still need to be considered alongside the conditions and how you felt that day.
  • The Talk Test
The talk test is a simple way to gauge effort without specialized equipment. As you approach aerobic threshold, your breathing usually deepens, but you can still speak in full sentences and hold a reasonably comfortable conversation. As intensity rises further, talking becomes less comfortable.
  • The Heart Rate Drift Test
A heart rate drift test looks at how your heart rate changes during a sustained, steady effort. Choose a flat route, maintain a consistent pace or power output, and compare your heart rate in the first and second halves of the session.
A noticeable rise at the same output may suggest that the effort is becoming harder to sustain aerobically. A smaller change generally suggests that you are handling the effort well. Weather, fatigue, hydration, and route conditions can also affect heart rate drift. Use repeated tests to follow trends over time rather than treating a single result as a precise measurement of AeT.
  • Tracking Aerobic Fitness With Suunto
Your Suunto watch and Suunto app can help you follow changes in aerobic fitness over time. Metrics such as VO₂ max and training load, along with lactate threshold estimates on supported models, provide context for understanding how your endurance is developing.
For a closer look at exercise intensity around your aerobic threshold, use a compatible heart rate belt with Suunto ZoneSense. ZoneSense analyzes the timing between heartbeats to assess your body's response to exercise, helping you identify intensity changes associated with thresholds such as AeT and LT1. You can also review these insights after your workout.
These estimates can help guide training, but they do not replace laboratory lactate or gas exchange testing.
Zonesense widget in Suunto watch and app with HR belt
How to Improve Your Aerobic Capacity?
Improving aerobic threshold takes consistent endurance training at a level you can handle, plus enough recovery for your body to adapt. The aim is to sustain more speed or power with less physiological strain, rather than continually pushing your heart rate higher. Start from your current fitness, establish a routine you can maintain, and then adjust duration and intensity gradually.
1. Building an Aerobic Base With Easy Runs and Long Runs
Easy runs and long slow distance training both help you accumulate low-intensity endurance work. Regular easy runs build consistency, while gradually extending some of those runs develops your ability to keep going for longer.
Keep the effort below your individual AeT, at a level where you can talk comfortably. Let pace respond to the effort instead of pushing harder to hold a set number. If you use Zone 2 on your watch as a guide, first check the zone model and your personal settings.
If you are new to running or returning after a break, a run-walk approach can help you ease in. Daniels’ Running Formula includes the following session:
(1) Walk for 5 minutes.
(2) Run easily for 1 minute, then walk for 1 minute. Repeat 10 times.
(3) Finish with a 5-minute walk.
The session takes 30 minutes, with 10 minutes of running. Keep the running portions at E (Easy) intensity: relaxed, comfortable, and conversational. Use this as a starting point and adjust it to your fitness. You do not need to force yourself to complete every repetition or the full duration.
Source: Jack Daniels, Daniels’ Running Formula, 3rd ed., Human Kinetics, 2014. Chapter 7, “Fitness Training,” Table 7.1, “White Starting Plan,” Weeks 1–4, Day 1.
2. Improving Aerobic Threshold With Steady Aerobic Workouts
Once you have a consistent training routine, you can add steady aerobic workouts close to AeT. Here, 'steady' means holding an even, controlled output. It does not automatically mean lactate threshold intensity or a tempo run.
As you adapt, gradually extend your runs or increase distance. Change one variable at a time rather than increasing frequency, duration, and intensity together. With a compatible Suunto watch, you can create structured workouts in Suunto app with warm-up, main set, and cool-down phases to help keep the session on track.
set structured workouts in Suunto app
3. Managing Training Intensity With the 80/20 Training Method
The 80/20 approach is a way to distribute training intensity: roughly 80% at low intensity and 20% at higher intensities. The easy work generally stays below AeT, helping you accumulate endurance volume and build an aerobic base. Harder sessions are chosen to match your goals and develop speed and the ability to sustain higher-intensity efforts. Together, they provide different training stimuli while helping you manage overall fatigue.
The ratio applies to your training over a period of time, not to every individual workout. It also changes depending on whether you count sessions or actual time at each intensity. Adapt the balance to your fitness, goals, and recovery rather than trying to hit the percentages exactly.
Learn more about Training Intensity Management here.
Tip: Finding your AeT is one step in building a training plan. As you record workouts with a Suunto sports watch, look at VO₂ max, training load, and heart rate variability (HRV) together to follow your training status and changes in aerobic fitness. Over time, that record can help you see how your body is responding and adjust the training ahead.
Takeaways
Aerobic threshold connects a physiological marker with everyday training decisions. Understanding it helps you choose appropriate intensities and track your endurance development over time. The value lies in how you apply it: train consistently, give your body time to adapt, and look for improvements in what you can actually sustain out on the road or trail.
FAQ
Is Aerobic Threshold the Same as Zone 2?
Not exactly. Aerobic threshold is a physiological reference point, while Zone 2 is a training intensity range. AeT often sits near the upper end of Zone 2 in five-zone models, but the boundaries vary by system.
Should I Train at or Below My Aerobic Threshold?
Keep everyday easy sessions below AeT. Steady workouts close to AeT are also useful, with intensity adjusted for session length, recovery, and conditions.
Can Walking Help Improve My Aerobic Base?
Yes, if it provides enough stimulus for your current fitness. Brisk walking or a run-walk approach helps beginners build endurance while keeping the effort manageable.
How Long Does It Take to Improve Aerobic Threshold?
There is no fixed timeline, because progress depends on your training history, consistency, volume, and recovery. Look for trends across a training block, such as a faster pace at the same heart rate under similar conditions.
Can an Aerobic Threshold Calculator Give an Accurate Result?
A calculator gives you an estimate, and its accuracy depends on the method and your input data. Treat the result as a starting point and check it against how you feel and perform during training.
Does Heart Rate Drift Mean I Have Exceeded My Aerobic Threshold?
Not necessarily. Heat, hydration, fatigue, and exercise duration can all raise your heart rate at a steady pace. Heart rate drift alone does not prove that you have exceeded AeT.
