Shakeout Run: What It Is, Why It Works, and How to Do It Right
SuuntoRun — 9 ноября 2026
It's the evening before race day. You've picked up your bib at the expo, and your legs feel heavy after hours of flying, driving and shuffling through exhibition halls. Your body is tired, but your mind is wide awake with pre-race excitement and nerves. With the start line waiting tomorrow morning, one question creeps in: should you head out for a short jog right now?
It's one of the most common questions of race week, and the answer lies in the shakeout run.
In running communities and race-prep plans, this short pre-race jog has a name: the shakeout run. Some runners treat it as an essential ritual to wake up the body. Others worry that every extra step spends energy they'll need on race day. Exercise physiology and real-world training practice show what a shakeout run does, when it makes sense and how to keep the intensity in check, so you can combine your own habits with objective data and choose confidently between an easy jog and a full rest day.
What Is a Shakeout Run?
A shakeout run is a short, very easy jog done the day before a race or on race morning. Its purpose is to keep your body connected to its natural running mechanics and cadence through a gentle dynamic stimulus, with no added training load or muscle fatigue. Mileage and aerobic fitness are built earlier in your plan. Done right, a shakeout run leaves your legs feeling lighter and fresher than when you headed out the door.
Before a marathon, a typical shakeout run is a very easy jog of about 10 to 30 minutes, even more relaxed than a normal easy run. Both that duration and the rough distance of 2 to 5 km are practical reference ranges shaped by coaches and runners over years of race preparation, rather than fixed rules.
What Are the Benefits of a Shakeout Run?
"Shakeout run" is a term from everyday training and racing. There's a few different reasons you do them, so we'll help shed light on how it works and why you should consider adding them to your training.
Maintaining Pre-Race Readiness
Once your taper begins and weekly mileage drops sharply, your body gets the chance to recover from accumulated training load. After several days without running, though, some runners find their legs feel wooden and their stride awkward, a state often called "feeling flat." A meta-analysis of 27 experimental tapering studies found that the most effective tapers progressively cut training volume while maintaining existing training frequency, keeping a regular exercise stimulus throughout. An experimental study on middle-distance runners found the same pattern: athletes who kept up short, frequent daily sessions during the taper achieved significantly better 800 m performance and physiological readiness than those who took a full rest day every third day.
A shakeout run follows the same thinking. A brief, very light dynamic stimulus may help you hold on to a familiar running rhythm and physical state. If you usually run most days of the week, this gentle activation helps you keep a familiar feel for the ground at the start line while keeping extra fatigue to a minimum.
Keeping the Legs Moving
If you're traveling to an out-of-town race, the journey itself is often one of the biggest challenges of the final day or two. Hours on a plane, a high-speed train or in a car, followed by long stretches in a hotel room, can easily leave your legs heavy. A short shakeout run after you arrive gets stiff legs moving again, shakes off the post-travel sluggishness and helps you find a light, easy stride.
On the physiological side, a meta-analysis on prolonged sitting and vascular function shows that after several hours of uninterrupted sitting, blood vessel dilation in the legs drops while the arms remain largely unaffected, and that breaking up sitting time with a few minutes of light lower-body activity largely offsets the drop. A randomized crossover trial observed a similar pattern: lower-limb arterial stiffness rose after three hours of continuous sitting, and one minute of bodyweight movement at regular intervals reversed the trend. These studies stop short of proving that a shakeout run improves circulation or race times, but in real-world race prep, a short, very easy jog is a practical way to get your body moving.
Easing Pre-Race Nerves
Evidence on the mental side is more indirect, but runners feel the effect widely. As a big race approaches, pent-up energy from the reduced taper volume mixes with worries about pacing and finish goals, and restlessness sets in. A meta-analysis of 36 randomized controlled trials shows that a single session of aerobic exercise produces a small but statistically significant reduction in acute state anxiety.
This is a real but modest aid, one factor among many on race day. Still, a calm, unhurried jog through a park or along a path near your hotel draws your attention away from replaying tomorrow's race and back to steady breathing and footstrikes, making it easier for mind and body to settle the night before.
Should Runners Do a Shakeout Run?
A shakeout run can help on race day, and it's entirely optional. Weigh your race-prep situation and your body's recovery signals to decide whether to run or rest.
When a Shakeout Run Is Worth Doing
Based on the physiology above and practical experience, a shakeout run is usually worth doing in three situations:
  • After long travel or prolonged sitting: Hours of flying or driving to an out-of-town race often leave your body and legs feeling heavy. Once you've settled in at your destination, a short jog loosens up the joints and muscles of your lower body.
  • If you run often and already do a pre-race easy run: If you log higher weekly mileage or train frequently, and you routinely schedule an easy run the day before a long run or hard workout, sticking to that rhythm is safer than switching to several full rest days in race week, and it keeps your body from going stale.
  • Before a short race like a 5K or 10K: These races start fast from the gun, so arriving ready matters. Some research suggests that pre-competition priming exercise may help the body adapt more quickly to the high-intensity effort that follows. Priming exercise and a shakeout run are different things, though. If you're already used to pre-race easy runs, consider a short, easy jog the day before, depending on your habits and recovery.
When to Skip or Shorten a Shakeout Run
Recovery always comes first. Weigh whether a shakeout run is worth it based on how well you're recovering and the conditions around you:
  • Sleep debt or extra fatigue: After a poor night's sleep, alcohol the evening before, or a high step count from walking the expo and sightseeing during race week, your body needs to save its energy for the race. Shorten the jog to around 10 minutes, or skip it and take a full rest day.
  • Poor conditions or a history of slow recovery: Bad weather, slick or crowded streets, a tight race-morning schedule, poor subjective recovery, rising fatigue, or a past pre-race jog that left you tired for more than a day are all good reasons to shorten or skip it. Your Suunto watch's "Recovery" reading gives you an objective reference: if it shows "Fair" or lower, your readiness may be below par, and shortening or skipping the shakeout run is worth considering. Always judge readiness alongside how your body actually feels, rather than on a single number.
How to Do a Shakeout Run Right
Once you've decided to head out, the key is running it without turning it into a drain. Get three things right and the run will support your race-day readiness: timing, duration and intensity.
How Many Hours Before the Start Should It Happen?
Depending on race distance and start time, you have two main timing windows:
  • The day before the race (about 18 to 24 hours before the start): The most common and dependable choice, especially for half marathons and marathons. Running in the morning or early afternoon loosens up your body and leaves the rest of the day for rest, hydration and carbohydrate loading, while keeping late-day exercise from disturbing your sleep.
  • Race morning (about 2 to 2.5 hours before the start): More common before shorter races like a 5K or 10K, or as an extra wake-up routine for experienced runners, with plenty of buffer before corral check-in and your official warm-up. If your race starts very early, breakfast, transit, bag check and corral entry already fill most of the morning, so the day before is the better choice.
How Long Should a Shakeout Run Be?
Use 10 to 30 minutes as a general guide. There's no set distance or time for each race distance, so within that window, tailor the duration to your usual training and how your body feels that day:
  • Lower-mileage or first-time racers: Aim for the short end. There's no need to copy the shakeout mileage of elite athletes, and 10 to 15 minutes is often plenty to wake up the neuromuscular system and settle pre-race nerves.
  • Frequent runners used to pre-race jogging: 15 to 25 minutes works well. Keep it under 30 minutes.
A simple cue for when to stop is the feeling that your body has loosened up. Once a light, easy rhythm clicks in, finish a few minutes early rather than adding load just to round off a kilometer or a time on your watch.
How Fast Should a Shakeout Run Be?
Err on the slow side and keep it very easy, ideally a notch slower than a regular easy run. A review of pre-race tapering published in Sports Medicine shows that tapering often brings marked gains in muscle strength and power, driving overall performance improvements. Those gains are linked to falling creatine kinase levels as training load drops, a sign that training stress and muscle micro-damage are being repaired. Keeping your shakeout run easy protects that recovery and adds no extra fatigue.
In practice, combine how you feel with objective watch data to keep the intensity low:
  • How you feel (RPE and the talk test): Keep your rate of perceived exertion (RPE) at 2 to 3 out of 10, with light, steady breathing that passes the "talk test" the whole way, meaning you can speak in full sentences with ease.
  • Objective data (heart rate zone monitoring): A compatible Suunto watch shows your intensity zone in real time, a useful aid for keeping effort in check, though how easy the run feels should remain your main guide. Aim to stay around Zone 1, typically 50% to 60% of maximum heart rate. Suunto supports both default zones and custom personal heart rate zones. To set it up, open the "Running" mode, scroll down to "Exercise options", select "Intensity zones" and then "HR zones", press the "lower button" to set the target zone and tap "Zone 1". If your heart rate rises above Zone 1 during the run, the watch alerts you.
Common Mistakes in a Shakeout Run
Even when you know the duration and heart rate guidelines, race-week emotions and distractions can still lead to missteps. Here are the four most common shakeout run mistakes and how to sidestep them.
Running Too Fast or Too Long
This is the classic mistake. Fresh from the taper, you step out the door feeling energized and light on your feet, the pace creeps up without you noticing, and a relaxed loosener turns into a moderate workout. Or you feel so good that you run well past the 30-minute mark.
Trying New Things Before the Race
Save new gear for after the race. The most common mistake is lacing up brand-new race shoes for a shakeout run, or wearing new socks, shorts or a sports bra. Even on a 15-minute jog, untested shoes or seams can cause blisters or chafing.
Getting Swept Up by the Group
Around major races, brands and running clubs often host lively official or community shakeout runs. Joining one is a great way to soak up the race-weekend atmosphere, but the biggest trap is getting pulled along by the crowd: running faster or farther than planned, or comparing paces with others, which defeats the purpose of keeping it very easy. A sports psychology study found that when other runners were present, social facilitation led athletes to run the first 500 m significantly faster than when starting alone.
The study doesn't test group shakeout runs directly, but it clearly shows the tendency to speed up unconsciously in company. If you join a group shakeout, use the methods above to keep your intensity firmly in check. If you know you'll get carried away, a solo run is the safer bet.
Cutting the Timing Close or Overreading Your Legs
Two other details are easy to miss. The first is timing it too close: on race morning especially, running too near the gun rushes corral check-in, bag drop and bathroom stops, and eats into your recovery buffer. The second is treating how your legs feel on the shakeout as a forecast for race day.
Some runners feel slightly heavy-legged and start worrying about tomorrow, yet heavy legs the day before are common and say little about how you'll race.
Conclusion
Back to the original question: should you head out for that short jog the day before the race? The answer comes from your own training habits and how your body responds, rather than a one-size-fits-all template. A shakeout run is a helpful option rather than a must. Done right, it keeps your familiar feel for the ground and takes the edge off pre-race nerves. When you're tired, a full rest day is an equally smart call.
For the most reliable answer, test it ahead of time instead of trying it for the first time in race week. Pick a regular long-run day in your training cycle, do a short shakeout run the day before, and pay attention to how light your legs feel, your overall fatigue, and your pace and heart rate in the next day's session. Once you know how your body responds in training, the call the night before the race comes naturally.
FAQ
How long should a shakeout run be?
Generally 10 to 30 minutes. Adjust the exact duration to your training experience, daily habits and race distance, and treat 30 minutes as the upper limit.
Should you wear your race kit?
Yes, as long as it's broken in. Wearing the singlet, shorts and shoes you plan to race in, even with your bib pinned on, is a final check that everything fits and moves without chafing, and it brings you closer to race-day feel. The one firm rule: every item must already be thoroughly tested in training. Save brand-new shoes and socks for after the race.
Can a shakeout run hurt performance?
If you're used to pre-race easy runs and well recovered, a short, easy jog usually adds no noticeable fatigue. The real risk is overdoing it, stretching the distance or pushing to normal training pace because you feel good, and turning a relaxed jog into a draining workout. If you're already noticeably tired before the race, a full rest day is the safer choice.
