FREE SHIPPING OVER R3,000 | SIGN UP FOR NEWSLETTER | NEW LOWER PRICES
Suunto 7 User Guide
Charge your watch
Charging Suunto 7 is easy and fast. Connect the supplied USB cable with a USB port on your computer or a USB power adapter and power outlet. Place the magnetic end of the USB cable into the charging socket on the back of your watch.
When your watch is charging, you will see this symbol Lightning bolt S7 on your watch face.
If the battery is completely discharged, charging must be done by a USB power adapter and power outlet.
Good to know
Your watch – and the charging socket – can get dirty as you use it, especially when you exercise. To make sure your watch can charge properly, wash the watch body once in a while to remove sweat or any body lotion you might have on your skin. Use lukewarm water and mild hand soap to wash the watch body, rinse well with water and pat the device dry with a towel.
Charging time
Check your battery
Get automatic updates and download offline maps during charging
Charging time
It takes about 100 minutes to charge Suunto 7 from 0 to 100% using the included charging cable.
Check your battery
quick-shade-battery-level
While on the watch face, swipe down from the top of the screen to see how much battery you have remaining.
Maximize your watch's battery life
charging-automatic-offline-maps-download
If you’re connected to Wifi while charging, you can keep your watch and apps up to date and get local Suunto maps downloaded automatically to your watch. With offline maps, you can leave your phone behind, go out and use Suunto Wear app with maps without needing an Internet connection.
Manage automatic app updates
Learn more about offline maps
