A point of interest, or POI, is a special location, such as camping spot or vista along a trail, you can save and navigate to later. You can create POIs in Suunto app from a map and do not have to be at the POI location. Creating a POI in your watch is done by saving your current location.
Each POI is defined by:
You can store up to 250 POIs in your watch.
You can add a POI to your watch either with Suunto app or by saving your current location in the watch.
If you are outside with your watch and come across a spot you want to save as a POI, you can add the location directly in your watch.
To add a POI with your watch:
You can remove a POI by deleting the POI from the POI list in the watch or removing it in Suunto app.
To delete a POI in your watch:
When you delete a POI from your watch, the POI is not permanently deleted.
To permanently delete a POI, you need to delete the POI in Suunto app.
You can navigate to any POI that is in your watch POI list.
When navigating to a POI, your watch uses full power GPS.
To navigate to a POI:
Select Start exercise if you want to use the POI for exercising or select Navigate only if you only want to navigate to the POI.
If you only navigate to the POI, nothing will be saved or logged in Suunto app.
The POI navigation has two views:
POI view with direction indicator and distance to the POI
map view showing your current location relative to the POI and your breadcrumb trail (the track you have traveled)
Press the crown to switch between views.
If offline maps are activated, the map view will display a detailed map of your surroundings.
In the map view, other POIs nearby are shown in gray. In the map view, you can adjust the zoom level by turning the crown.
While navigating, you can press the lower button to open the navigation menu. The menu gives you quick access to POI details and actions such as saving your current location or selecting another POI to navigate to, as well as ending navigation.
The following POI types are available in Suunto Race S:
![]() | Begin |
![]() | End |
![]() | Car |
![]() | Parking |
![]() | Home |
![]() | Building |
![]() | Hotel |
![]() | Hostel |
![]() | Lodging |
![]() | Bedding |
![]() | Camp |
![]() | Camping site |
![]() | Camp fire |
![]() | Aid station |
![]() | Emergency |
![]() | Waterpoint |
![]() | Information |
![]() | Restaurant |
![]() | Food |
![]() | Cafe |
![]() | Cave |
![]() | Mountain |
![]() | Peak |
![]() | Rock |
![]() | Cliff |
![]() | Avalanche |
![]() | Valley |
![]() | Hill |
![]() | Road |
![]() | Trail |
![]() | River |
![]() | Water |
![]() | Waterfall |
![]() | Coast |
![]() | Lake |
![]() | Kelp forest |
![]() | Marine reserve |
![]() | Coral reef |
![]() | Big fish |
![]() | Marine mammal |
![]() | Wreck |
![]() | Fishing spot |
![]() | Beach |
![]() | Forest |
![]() | Meadow |
![]() | Coast |
![]() | Stand |
![]() | Shot |
![]() | Rub |
![]() | Scrape |
![]() | Big game |
![]() | Small game |
![]() | Bird |
![]() | Prints |
![]() | Crossroads |
![]() | Danger |
![]() | Geocache |
![]() | Sight |
![]() | Trailcam |
