Suunto Smart Sensor User Guide - 1.1
Handling guidelines
Both the Suunto Smart Sensor module and belt should be rinsed with fresh water after each use.
CAUTION:
Do not pull the Suunto Smart Sensor module off the belt. This may damage the belt connectors. Unsnap one side at a time.
The belt should be machine washed in 30° C after every 2-3 exercises. See the belt tag for further washing instructions.
CAUTION:
Do not machine wash the Suunto Smart Sensor module. Machine washing damages the module.
You do not need to replace the Suunto Smart Sensor module; only the Suunto Smart Sensor belt may eventually need replacing after extended use.
