How do battery modes work during multisport trainings?
For every sport mode you can choose one the predefined battery modes: Performance, Endurance and Ultra. By default, Performance will be activated. You can also create a custom battery mode. When you defined a custom battery mode, this mode will be used by default.
During multisport exercises the same logic applies:
  1. When you start an exercise using e.g. Endurance mode and then switch to a sport that does not have a custom battery mode configured, Endurance mode remains in use.
  2. When you start an exercise using e.g. Endurance mode and then switch to a sport that does have a custom battery mode configured, the battery mode is switched to custom along with the sport.
  3. When you start an exercise using the custom battery mode and then switch to a sport that does not have a custom battery mode configured, the battery mode is switched to the default mode Performance along with the sport.
RELATED ARTICLES:
How do I get the most out of the battery modes?
How does GPS accuracy in battery mode impact the tracking of my exercise?
What affects the accuracy of the battery life estimation?
Can I set or adjust battery modes in the Suunto app or Suunto Movescount?
How do sport mode settings in Suunto Movescount affect the battery mode settings in Suunto 9?
FIND MORE SUPPORT FOR:
