Bearing navigation
Bearing navigation is a feature that you can use outdoors to follow the target path for a location you see or have found on a map. You can use this feature stand alone as a compass or together with a paper map.
If you set the target distance and altitude while setting the direction, your watch can be used to navigate to that target location.
![Bearing Navigation S9PP](/contentassets/d8b5fef901a34c0bb6556437b0b7ef22/bearing-navigation-s9pp_4.png)
To use bearing navigation during an exercise (only available for outdoor activities):
- Before you start an exercise recording, swipe up or press the lower button and select Navigation.
- Select Bearing.
- If needed, calibrate the compass by following the on-screen instructions.
- Point the blue arrow on the screen towards your target location and press the middle button.
- If you do not know the distance and altitude to the location, select No.
- Press the middle button to acknowledge the set bearing.
- If you know the distance and altitude to the location, select Yes.
- Enter the distance and altitude to the location.
- Press middle button to acknowledge the set bearing.
To use bearing navigation without exercising:
- Scroll to Compass by swiping up or pressing the lower button from watch face.
- Press the lower button to open navigation options.
- Select Bearing navigation.
- If you do not know the distance and altitude to the location, select No and follow the blue arrow to the location.
- If you do know the distance and altitude to the location, select Yes.
- Enter the distance and altitude to the location and follow the blue arrow to the location. The display will also show the distance and altitude left to the location.
- Press the lower button and select New Bearing to set a new bearing.
- Press the lower button and select End navigation to end the navigation.
