FREE SHIPPING OVER RM1000 | EASY RETURNS | SIGN UP FOR NEWSLETTER
Suunto Ambit2 R User Guide - 2.0
Using buttons
Suunto Ambit2 R has five buttons which allow you to access all the features.
buttons Ambit2
Start Stop:
  • access the start menu
  • pause or resume an exercise or timer
  • keep pressed to stop and save an exercise
  • increase a value or move up in the settings
Next:
  • change between displays
  • keep pressed to access/exit the options menu
  • keep pressed to access/exit the options menu in sport modes
  • accept a setting
Light Lock:
  • activate the backlight
  • keep pressed to lock/unlock the buttons
  • decrease a value or move down in the settings
View:
  • change views in time mode and during exercise
  • keep pressed to toggle the display between light and dark
  • keep pressed to access context-sensitive shortcuts (see below)
Back Lap:
  • return to the previous step
  • add a lap during exercise
When changing the values, you can increase the speed by keeping Start Stop or Light Lock pressed until the values start to scroll faster.
Defining shortcuts
By default, when you keep View pressed in Time mode, you toggle the display between light and dark. This button push can be changed to instead access a specific menu option.
To define a shortcut:
  2. Browse to the menu item to which you want create a shortcut.
  3. Keep View to create the shortcut.
Shortcuts cannot be created to all possible menu items, such as individual logs.
In other modes, keeping View pressed accesses predefined shortcuts. For example, when the compass is active, you can access the compass settings by keeping View pressed.
