Suunto D5 User Guide
How to set language and unit
To change the device language and unit system:
  1. Go to Main menu » General » Device settings » Language and select your language.
  2. Go to Main menu » General » Device settings » Units & formats.
    Menu units formats D5
  3. Select Date format, or Units, or Time format.
  4. Use the upper or lower button to select from the available formats.
    Under the unit settings, you have the option of selecting metric or Imperial as a global setting: it will affect all measurements.
  5. To set the unit system for specific measurements select Advanced. For example, you could use metric for depth, and Imperial for tank pressure.
