To customize Suunto EON Core:
When creating or modifying dive modes, you need to synchronize the changes with your Suunto EON Core before disconnecting the USB cable to save the changes to your device.
Customization is divided into four categories:
To customize categories:
Configure what you see under the Gases menu in Suunto EON Core.
Turn the Multiple gases option on or off. When on, the Modify gases while diving option becomes active.
When turned off, the gas menu is simplified and easier to use with only one gas.
Helium can also be activated here.
For Air / Nitrox and Gauge modes, you can create up to four custom views.
The style of the mode can be prominent, graphical or classic.
Prominent style presents key information with large numbers:
Graphical style presents information with additional visual elements:
With classic, information is presented in the traditional manner using numbers:
Within each view of the mode, you can define what information is shown in customizable fields. When editing the view in DM5, you get a preview of how it will look on your Suunto EON Core.
In each view, you can define switchable fields on the screen. In the selected view, you can cycle through these values by pushing the lower button. These customizable data fields are different from each other depending on the layout selected (classic, graphical or prominent). Use DM5 to customize these fields and learn more.
